Question about HP Officejet 5510 All-In-One Thermal Printer
MY HP 5510xi all-in-one printer gives me the message "OPEN DOOR. Clear carriage jam ... press OK." but everything seems tight. The rear "jam" door is difficult to close but seems ok now & I've been thru the following HP solutions & found no problems & with no success. " Issue A 'Carriage Jam ' or 'Carriage Blocked ' error message displays on the product control panel. The carriage assembly, which holds the ink cartridges, stalls against the left side of the printer. The following symptoms might also indicate a carriage jam: The product won't print The printing stops unexpectedly A paper jam might have occurred previously. How to use the solutions in this document To resolve the issue, try each solution in this document in the order presented. IMPORTANT : Each time you try a solution, try to print a self-test report to determine if the hardware is functioning correctly. To print a self-test report, use the steps in the following table. How to print a self-test report Load plain, white paper into the input tray. Press Setup on the product control panel. Press 1 , and then press 4 . The Print Report menu displays, and then the product prints a self-test report. NOTE: Refer back to the steps in this table after attempting each solution. Solution one: Turn the All-in-One off and on again Follow these steps to turn the product on, and then off again, to reset the print mechanism. Press the Power button ( ) to turn off the product. Wait 15 seconds. Press the Power button ( ) to turn the product on again. NOTE: The product might go through a warm-up period of up to two minutes. The product lights might flash and the carriage might move. Wait until the warm-up period is complete before proceeding. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution two: Clear any paper jam Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper. Step one: Remove any loose paper Remove any loose paper from the input tray and output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear a paper jam from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the back of the All-in-One Press the Power button ( ) to turn off the product. Disconnect the USB cable from the back of the product. Disconnect the power cord from the back of the product. On the back of the product, press in the tab on the left side of the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access door Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur. Reattach the rear access door. Gently push the door forward until it snaps into place. Step three: Clear the paper jam from the front of the All-in-One If you cannot remove the paper jam from the back of the product, follow these steps to remove the paper jam from the front. Open the carriage access door. Lift up on the handle to open the door. Figure 2: Open the carriage access door Reach inside the product through the carriage access door and gently pull any paper out of the rollers. NOTE: Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism. Close the carriage access door. Reconnect the power cord to the back of the product. Press the Power button ( ) to turn on the product. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution three: Make sure that the carriage moves freely Use the following steps to make sure that the carriage moves freely. Press the Power button ( ) to turn on the product. Open the carriage access door. The carriage might move to the center of the product. Allow it to move to that position. Figure 3: Open the carriage access door Without turning off the product, disconnect the power cord from the back of the product. CAUTION: You must disconnect the power cord to move parts by hand without the risk of an electrical shock. Disconnect the power cord from the wall outlet. Look inside the product to see where the carriage is stuck, and then check for any torn paper or objects that might be restricting the carriage. NOTE: You might need a flashlight to illuminate areas for proper viewing. Reach inside the product through the carriage access door, and then manually move the carriage. If the carriage is stuck on the right side of the product , move the carriage to the left side of the product. If the carriage is stuck on the left side of the product , move the carriage to the right side of the product. If the carriage is stuck in the middle of the product , move the carriage to the right side of the product. Remove any loose paper or obstructions found. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Close the carriage access door. Reconnect the power cord to the back of the product. Reconnect the power cord to the wall outlet. Press the Power button ( ) to turn on the product. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution four: Remove and reinstall the cartridges Improper placement or installation of the cartridges can cause the product to indicate a carriage jam error. Follow these steps to remove and then reinstall the cartridges. Step one: Remove the cartridges Press the Power button ( ) to turn on the product. Open the carriage access door. The carriage might move to the center of the product. Wait until the carriage is idle and silent before continuing. Figure 4: Open the carriage access door Push down on the top of the cartridge to release it, and then pull it toward you to remove it from its slot. Figure 5: Remove the cartridge Repeat these steps for the other cartridge. Check for obstructions under and around the carriage. Remove any obstructions. Step two: Reinstall the cartridges Slide the cartridge forward into the empty slot, and then gently push on the upper part of the cartridge until it clicks into place. Figure 6: Reinstall the cartridge If you are installing the tri-color cartridge, slide it into the left slot. If you are installing a black or photo cartridge, slide it into the right slot. Repeat these steps for the other cartridge. Close the carriage access door. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution five: Plug the product directly into a wall outlet Plug the product directly into a wall outlet to make sure the power source is functioning correctly. Disconnect the power cord from the back of the product. Disconnect the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet. Reconnect the power cord to the back of the product. Press the Power button ( ) to turn on the product. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document. NOTE: If the product prints when plugged directly into a wall outlet, the power strip or surge suppressor might not be allowing enough voltage to reach the product. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution six: Perform a power reset Use the following steps to reset the product. Press the Power button ( ) to turn on the product. Disconnect the power cord from the product. Unplug the power cord from the wall outlet. Wait 15 seconds. Plug the power cord back into the wall outlet. Reconnect the power cord to the back of the product. Press the Power button ( ) to turn on the product. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the self-test report prints successfully , but you continue to experience an issue with your product , then the issue is not related to the hardware. Go to HP Product Support Home Page , and then search for another document that relates to the issue you are experiencing. NOTE: If the page displays in the wrong region or language, click the Region - Language link in the upper right corner of your browser. Then you can select the correct region and language. If the product does not print a self-test report , there is an issue with the product hardware. Continue to the next solution. Solution seven: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product. Please correct my problem so my printer works correctly. Joe Tagert jctebay@hotmail.com
  • 4,889 Answers
Did you do all the has been advised and the problem persists? Did you check for paper jams?If yes then its some kind of obstruction on the beam on which the carriage rides. Turn your printer on and help the cartridge carriage move to its initial position if it is in the printing position.
Posted on Jul 10, 2010
  • 2 more comments
  • jctebay Jul 10, 2010
    what is the starting position of the cartridge/carriage?
  • eagle338
    eagle338 Jul 10, 2010
    The carriage moves from side to side during printing. My guess is that it is not able to return to its initial position and is struck in the middle or at the printing position. Try moving it from side to side to see if there is a mechanical obstruction.
    I looked at the carriage more closely w/a flash light & there appears to be some kind of groove on it in about the place where it jams & there appears to be another, although not quite as deep, on the side of the carriage. I can't see it very well but it doesn't appear to be made that way on purpose., any suggestions?
  • eagle338
    eagle338 Jul 11, 2010
    Yes I agree that it is the source of the problem. That is the reason why you have been getting that error message. Unfortunately I don't think you can straighten it out.
How do i clear a carriage jame an ,sg find nothing wrong
Click the link below to go to the hp printer support page for your printer paper jam. Pay special attention to the rear door , as many people miss that detail when clearing paper jams.Also , you can click on the troubleshooting link at the top of that page, followed by "solve a problem " in the drop down box to get answers for other problems,
Clear carriage jam and press OK to continue Error Message Appears for HP...
Feb 14, 2015 | HP OfficeJet 7310 All-In-One InkJet...
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Carriage Jam
>follow the steps on this link to clear carriage jam on your printer
>please inform me if this has resolved your issue.thanks
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00243856&cc=us&lc=en&dlc=en&product=421139
Sep 29, 2009 | HP Photosmart 2610 All-In-One InkJet...
Carriage jam on HP Photosmart 3210 Printer
most likely the sensor on the paper path out of position, chech it out and put it back to where it have to be, good luck!
Dec 13, 2008 | HP Photosmart 3210 Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP Officejet 5510 All-In-One Thermal Printer Logo
132 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
