Question about Xantrex Technology Xantrex Xpower 1750 Plus High Power Inverter
14.1VDC going into inverter but no ACV coming out. Red fault light is on. Disconnected fan motor and checked with meter and shows open even on high ohm scale.Are Xantrex fan motors known to go bad?If the fan is bad could there be something else wrong in the inverter that caused the fan to go bad? thanks for your help. Allan
    Problem Solver:
  • 14 Answers
If you don't have enough current to run the inverter, even at 14.1 v, it will go into protection. Make sure the wiring is heavy enough to provide the current needed to run the inverter. There should be a label on the fan saying what vosges it needs to run. Try powering up the fan outside the inverter.
Posted on Nov 26, 2017
2 Suggested Answers
ithana
  • 185 Answers
SOURCE: xantrex power inverter 1750
Sir ,
  one of the ic or resistor will be damaged inside ,so kindly replace it,it will be alright.
Posted on Sep 07, 2008
My breaker is showing 117 volts coming out of it but my light switch has only 3volts ???
You're not reading the light switch correctly, Charles. You may have your meter set to DCV instead of ACV, or you might be reading from hot to some ungrounded, non-neutral wire, or you may be reading through some high-resistance or solid-state load.
117VAC is perfectly satisfactory. Nominal is 120V, but anything from about 110 to about 130 is fine.
Aug 11, 2014 | Dryers
Hi, i have a 5kw sunteams inverter that regularly comes up with "hi dc inject" with red led "fault" light and shuts down the output. This is the 3rd inverter i have had in 10 months...
hi, I also get one sunteams inverter, it works quite well. One month ago it had High DC problem and I contacted the manufacture and this problem was solved. you can contact them at service@kinglongpower.com
Jun 15, 2011 | Electronics - Others
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
Fujitsu inverter air cond. Just stopped working properly. Model outdoor AOT30PMAL indoor unit AST30PBA-W. Code oper. Red led flashes fast continously green led (timer) repeats 13 slow flashes. After power...
It sounds like your inverter is at fault. You will need an inverter tester ( most good service techs will have one ) to prove that the output to the compressor is correct. If the inverter is okay then it will be the compressor at fault with a location error or it is simply seized. A common fault that caused this was the eev remained closed (coil failure ) and caused the compressor to over heat.
May 11, 2010 | Heating & Cooling
Fujitsu inverter; opens vents but no red light, no cold air
check that it is set to cooling sounds like it may be set to heat in cooling mode the indoor fan should at least run
Mar 10, 2010 | Heating & Cooling
Red fault light comes on after about 10 mins and
Had a similar problem with the same inverter BUT to include a failing cooling fan.
NOTE:
Take it back and get your money back as soon as possible.
Replaced it with a pure sine inverter 1500 watt that is kicking **** 24 seven days a week on my solar / wind power system.
RECOMENDATIONS:
UPGRADE.
Hope this tip helps.
R/
David
Dec 24, 2009 | Inverter AIMS 1000 Pure Sine Wave Power ...
My fan on the unit (38CKS UNIT) is not turning?
Problems with the fan are one of several things to consider.
1. Is their power to the fan motor.
2. Does the capacitor for the fan hold a charge and/or discharge (There are metering devices that can identify the condition).
3. Are the fuses blown (If Applicable)
4. Is the breaker to the condenser tripped.
5. Are the windings on the motor closed or open.
6. Are the winding (when using an Ohm Meter, Check the resistance from ground to one of the lead wires, making sure power is disconnected and all leads are disconnected from the terminal points. There will be high resistance if there is not a short from the windings to the frame ground.
These are simple checks I make to determine the motors condition. Sometimes a wire does come loose or cut or even burned. I trace the wire from point A to B and also making sure the wire terminal connections are tight.
Jul 21, 2009 | Carrier 38CKC030 Air Conditioner
Kenmore side by side
You need to elaborate more. If it's just the light quit working, then check the bulb first, if it's good then use a meter to check if you are getting power to the socket (red lead to middle contact, black one to the metal ring) check with meter on ACV at setting 200 or so and it should read 110-121V. If that's good then keep backtracing until you find the problem.
Jan 27, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Mits diamond vision 65
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Dec 26, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Xantrex Technology Xantrex Xpower 1750 Plus High Power Inverter Logo
100 people viewed this question
Top Xantrex Technology Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Xantrex Technology Car Audio and Video Expert? Answer questions, earn points and help others
