Question about Bose Wave Radio
Bose model AWR1-1W wont turn on - Bose Wave Radio
  • tfrank1 Jul 10, 2010
    i dont have a multimeter. where is the fuse. the white ribbon has detached from the mother board
    you still there?
  • 1,284 Answers
Hi, i have the exact same AWR1-1W model for repair last week. I am assuming you have a meter and you also have soldering skills here.
You might want to check the Q4 transistor (2SC3792) for a short on the two outside pins. With the power disconnected, measure with a multimeter the resistance between the two outside pins of the Q4 transistor. If you measure anything between 0-3 ohms it is shorted. Replace this part with a similar part or you could replace it with the new Bose recommended part - 2SD438F-MP-E but it is very hard to obtain. I have used an 2SC2655 instead and had no problems so far with the radio. This radio also came in totally dead with no display nor the radio working.
Or perhaps it is just a fuse blown. There is 0.5A fuse inside the main board.
Take care
Posted on Jul 10, 2010
  • 1 more comment
    how do I get inside the radio
  • Shehu Pro
    Shehu Pro Jul 10, 2010
    Get a screw driver and unscrew all the screws behind the radio, then follow the instructions i gave to you earlier.
    while the radio is plugged into the wall if I pull out the electrical cord from the back of the radio it make a slight noise????
Siliconchip
  • 52 Answers
SOURCE: no power up
Considering that power is present, popping sound is caused by a faulty Q401, 5V supply for display.
Good Luck.
Posted on Jan 03, 2008
hawkwatcher
  • 67 Answers
SOURCE: bose model awr1-1w
I may be able to help
kstahl65@att.net
Posted on Jan 14, 2008
SOURCE: bose radio won't turn on
check Q4 for short and replace
Posted on May 04, 2008
SOURCE: Station preset on AWR1-1W bose radio
I found out you tune the radio to the station you want to preset, and hold the preset button (1-6) that you want to assign it to until it beeps. And it's set.
Posted on Jan 09, 2009
SOURCE: My Bose Wave Radio, Model AWR1-1W, has no sound
I found a solution on a similar problem saying the audio amp IC is damaged. You will probably need to replace this. Unfortunately I don't know which IC it is.
Posted on Apr 30, 2009
Bose stereo wont turn on but the clock is working
Does it have power, the clock runs off a separate fuse. So pull the unit out and check to see that one wire is powered when the key is turned to run.
Apr 13, 2017 | Bose Audio Players & Recorders
My bose cinemate wont turn on
It is most likely a problem with the acousticmass. There has been a lot of issues with the Bose cinemate. Most of these issues require you to contact Bose. Make sure you have proof of purchase. They will charge a flat fee to fix it or if they can't they will offer you a discounted one as long as it's covered under warranty. 10_21_2013_5_59_43_am.png
Oct 05, 2013 | Furniture
Bose Cinemate wont turn on. I believe the remote control is not communicating with the unit. How can we reset the remote control?
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Aug 26, 2011 | Bose Cinemate Digital Home Theater System...
I just bought the ipod nano 6th generation and it will not charge in the Bose docking system....my old one charges with no problem.....is there a fix for this? The nano plays fine it just wont charge
If it is a different model iPod then it is likely the Bose dock does not support the newer model. Quite often changes such as from iPhone 3 to iPhone 4, Bose had to release a new dock. The speakers and music will still always work, but the support will be limited for charging. Unfortunately you will not be able to fix this, other than upgrade the dock, or go back to your old ipod.
Thumps Up!
May 04, 2011 | Bose SoundDock Digital Music System for...
My bose wave radio wont turn on. It has no power
I have the exact same AWR1-1W model for repair last week. I am assuming you have a meter and you also have soldering skills here.
You might want to check the Q4 transistor (2SC3792) for a short on the two outide pins. With the power disconnected, measure with a multimeter the resistance between the two outside pins of the Q4 transistor. If you measure anything between 0-3 ohms it is shorted. Replace this part with a similar part or you could replace it with the new Bose recommended part - 2SD438F-MP-E but it is very hard to obtain. I have used an 2SC2655 instead and had no problems so far with the radio. This radio also came in totally dead with no display nor the radio working.
Jun 06, 2010 | Bose Wave Radio
Bose 321
got the same problem
Jul 05, 2008 | Bose (321GS) System
Bose wave radio wont turn on
I have one that is doing the same thing. Will your radio make a POP sound when you unplug it? I was told by Bose Tech it is 15 yrs old and they will not work on it. He told me that if it makes a POP sound that it is not the fuse or power supply???
May 04, 2008 | Bose Wave Radio
Bose Wave Radio Logo
480 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
