Question about Compaq Presario CQ60-220US PC Laptop
My laptop seems to be overheating in the top left corner underneath (when holding the laptop upright as in use) and it gets so hot that it turns itself off. Any ideas how I go about getting it fixed? Its less than a year old.
    Scholar:
  • 67 Answers
This could be caused by either a broken cooling fan, or a clog in the fan system, trapping the hot air in the laptop and tripping a heat sensor to turn the laptop off. To check for this, remove the laptop case (several small screws on the bottom) and check for a hairball like clog somewhere in the path of the cooling system. This is common when laptops are used in places with pets and/or smokers.
Posted on Jul 18, 2010
In most cases It's the air passage/s blocked in the cooler cores before the fan inside. All it needs is clean up. But can you do it. If not, then get it done by a serviceman. I recommend it's cleaned at least once in a year
Posted on Jul 24, 2010
  • 487 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi, laptops because of there design can have over heating problems, it is important they are used on a flat hard service so air can circulate around. Also older batteries when they start to fail, are constantly taking on a charge, so they can get very hot; a new battery will solve this problem, but not necessarily a cheep option.
Hope this helps
Posted on Jul 10, 2010
LG front load washer is leaking underneath the front left corner, the display code is FE.
Why don't you simply find out what the FE code is alluding to? Go to web site or do a google search and then you can check for the issue further.
Sep 17, 2017 | LG WM2487H Front Load Washer
Dell Inspiron 6000 turns on but does nothing else.
From the description the hard drive has failed or windows has corrupt files. Unplug power supply from laptop and remove main battery, press and hold power for 2 minutes to remove residual voltage. when finished install battery and power supply now power up.
May 03, 2012 | Dell Inspiron 6000 Notebook
HP Pavilion dv5 gets hot in left hand corner. I've had this laptop for 9 months with no problems. This morning I noticed it getting very hot on the left front corner where my left hand rests. About...
HP Tech Support & HP help phone number 1-8002044427 for troubleshoot HP problems.Our certified technicians are available 24/7 to deal with your HP ...
Jun 01, 2017 | Computers & Internet
Severe Overheating and Noise.
sounds like your main cooling fan has packed in, if i were you i would get it repoaired asap, if you continue to use it you could make it even worse. Or not work at all
Dec 30, 2009 | HP Pavilion dv5215us Notebook
How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Jun 25, 2009 | Frigidaire FMV156DC Microwave Oven
Black screen, blinking cursor in top left hand corner
Could be a number of issues, incl unseated processor or a faulty hard drive. First off I would remove mains & battery, remove covers from underneath and reseat any memory or processors you can find - by reseat I mean just take out and put back.If this fails, I would look to price up a new hard drive before condemning the machine.
Apr 28, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
When I turn on the lap top the acer logo comes up and the lower left corner says press f2. I do that and it says in the left corner please wait. It runs another 1-3 min and then shuts off.
sounds like overheating or possible bad ram.
try dusting out with a can of air..especially where the vents are and see if some dust bunnies fly out.
Apr 10, 2009 | Acer Aspire 5000 Notebook
Overheating saxo
you not moving water ( water pump ) is where i'd go
hope2help shack
Apr 04, 2009 | 1989 Peugeot 405
Inspiron 5150 fan continously running
Dell Inspiron 5150, has overheating problems. The position of the fan is a problem.Also,don't press of the left upper corner of the laptop.Here's an excerpt from a wikipedia article: "The overheating problems on the Inspiron 5150 model was due to the position of the fan and fan-vent and the way in which it vents air through the CPU's heatsink.[citation needed] The fan draws air from underneath the unit and vents it through the rear after passing over the heatsink. However, the unit also sucks up dust from underneath it. Over time a buildup of dust constricts the airflow through the unit, reducing cooling. The airflow is perceptibly diminished. A simple test is to place a hand near the fan vent; when the fan is running at high speed there should be a good flow of warm air. Heat will also build up along the top of the unit near the LCD display and left toward the optical drive. Users may notice this while typing. Performance may also suffer, with jittery game movement and slow Windows performance. Some systems may experience jerky reactions where the unit goes into an almost slow-motion phase for short periods of time. Continued operation in this condition may lead to overheating and could result in permanent damage to the CPU, GPU, motherboard and other internal components. To remedy this the unit must be disassembled, the dust removed, and fan operation checked. This problem not uncommonly results in a CPU temperature-increase of between 15-20°C over an normally functioning unit. Further temperature increases may damage the casing of the unit."From Wikipedia article"Dell Inspiron" under problems Hope it helps -CG
Jan 20, 2009 | Dell Inspiron 5150 Notebook
Seems to be overheating..
Go to start -control setting- click on power setting, make sure it you have a check mark in it where it says : says never shut down
Nov 29, 2007 | Acer TravelMate 2500 Notebook
Compaq Presario CQ60-220US PC Laptop Logo
517 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
