Question about GPS
Tomtom touchscreen does not work. if you touch done or arrows it types in a "v" or some other letter. how do i fix problem
  • 677 Answers
In 90% of the cases it's the digitizer (the touch sensor that is mounted in front of the screen). You can try to replace it yourself or send it to a third party gps repair service.
This is a common problem with units having the serial numbers beginning with "14V", "12P" and "143". It's caused by a defective SHARP touchscreen and needs to be replaced. Please see this link for more info:
http://www.sharc.net/gps_LCD_repair.htm
Posted on Jul 18, 2010
Tom tom go 930 screen does not respond to touch.
Hi, Victor you can try to reset to default with a paper clip and make sure your battery is fully charged for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Touch screen TomTom EN
Repair Touchscreen Not responding for TomTom GO 930 Repair 4CH9 000 UK rep
TomTom GO 520 Touchscreen Problem
http://download.tomtom.com/open/manuals/gox30/FullManual/refman/TomTom-GO-en-US.pdf
Nov 03, 2016 | GPS
Does not work on the edges, can not access start by touching. when the screen is touched the arrow appears about half an inch away
Sounds like the calibration for the touchscreen needs to be reset. If you check in the control panel, there should be a ELO shortcut that allows you to calibrate/test the touchscreen. Try running through the calibration and see if the touchscreen behavior improves. If the calibration doesn't fix it, then you may have an issue with the touchscreen itself.
Mar 07, 2011 | Elo CarrollTouch touch-screen Monitor
The touchscreen acts like it is locked up. It will not go to any option that I touch. E.g.: "Home", "Recent Destination", "Address" and it will not move to the next screen when I touch the arrow.
If restarting does not help, go to TomTom website. The support tab provides self help and way to contact them. http://us.support.tomtom.com/app/home
Jul 05, 2010 | Tomtom ONE GPS Receiver
Hello, When typing on my Mo Droid if I want my caps to stay on how do I get that to work.....I tried holding it down but maybe I am not doing it properly?
If you are typing using the touchscreen, the upper-case arrow, touched once, will upper-case the next letter you type and then back to lower case. It you touch the upper-case arrow twice in a row, you should see a green light come on directly over it. That keeps the caps lock on.
If you are using the slide-out keyboard, touch the upper case key once and you should see a triangle underneath the cursor on the screen. That will upper case the next letter you type. To get it to stay in upper case, hit the upper case button again and the triangle should change to a > symbol, point up, underneath the cursor. That should keep it in upper case mode. Don't hold the upper case button down, as that won't do anything. A third press returns it to normal (lower case).
Jun 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Tomtom one stuck on Gaum. Live in Oregon! How do I make it work again?
On the regular display touch the screen once to bring up the options display.
Now touch the spanner/ wrench icon once
Use the right arrow until you see Manage Maps
Now select Switch Map
Select the one you want as Default.
It may take a little time to swap over
Now touch Done
Sep 13, 2009 | Tomtom ONE GPS Receiver
How do I delete addresses from my Tomtom?
There are two ways
One is from the TOMTOM itself
Touch the map display once.
Select the spanner / wrench icon
Press the right arrow until you see MANAGE FAVOURITES.
Select the one you wish to delete and the display will change.
At the bottom of the screen will be a DELETE button use that.
It will ask for confirmation click YES.
Click DONE when you have finished.
Two is via TOMTOM home
Start TTH
Connect your GPS
Start the GPS
TTH will probably offer you updates (let it do its thing)
When the update is done use the right arrow on your PC display and select OPERATE My TOMTOM
Now use the same method as you did above.
To delete ALL recent destinations
Touch the map once
Touch NAVIGATE TO
Select RECENT DESTINATIONS
Now select DELETE
It will ask for confirmation select YES
they will all be deleted and the flag will grey out .
Touch BACK
Touch DONE.
Sep 07, 2009 | Tomtom ONE GPS Receiver
How do i set the time on my tomtom xl
When it is on a map display touch on the map
Now touch the icon that looks like a spanner / wrench
Use the right arrow to scroll screens until you see the one that says "set clock"
Touch that and use the up/down arrows over the numbers to move them as you need.
Press done
Aug 28, 2009 | Tomtom One XL GPS Receiver
Tomtom one touch screen not working properly
Here is the cal.txt I used for my 720
929 86 480 75
It is really close to perfect
open a text file put these numbers in save as cal.txt copy this file connect tt to computer go to explorer/aka file manager find tomtom drive and paste it in.
That is it. test it out.
May 11, 2009 | Tomtom GO 720 GPS Receiver
we can help solve this problem, we have touch screens for replacement
Fargohill
Mar 22, 2008 | Tomtom ONE GPS Receiver
Re-calibrate Screen on Tom Tom One Regional
I tried this to fix my tomtom one, but it didn't work.
It may be worth a try on other models, though....
http://www.yournav.com/forum/index.php?showtopic=12622
Mar 11, 2007 | Tomtom ONE GPS Receiver
GPS Logo
15 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
