Question about Garden
I am mixing 40 oz of concentrate to water to make a total of 1.33 Gallons. How many oz of water to each oz of concentrate?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
You need one gallon of water (128 ounces if you want to measure it that way. When you add that to 40 oz of concentrate, you'll get 1.33 gal of mixture.
Posted on Aug 07, 2010
What is the mixing ratio to 1 gal of water?
Their products are here, but they don't tell you the usage. It has to be on the label by law. The rear label usually lifts up to reveal a small book of three or four pages. If it isn't there, contact the company via the website.
http://www.spectracide.com/Products-and-Solutions/Lawn-Weed-Killers.aspx
The does have label details here
http://www.spectracide.com/Customer-Help/Labels-and-MSDS.aspx
For the Spectracide it is 1/2 oz to a gallon, but it depends on what type of grass you have. I will copy and paste the label details, but I doubt the format will stick, but it is all there.
Ounces of Concentrate to Use for:
St. Augustine*,
Bahia,
Centipede
2/3
2 2/3
13 1/3
21 1/3
32
32
1/2
16
250
1,000
5,000
8,000
Sq ft
to be
Treated
Bluegrass,
Fescue, Rye,
Zoysia
Gallons
of
Water
*DO NOT USE ON FLORATAM VARIETY OF ST. AUGUSTINEGRASS IN
FLORIDA.
HOW MUCH TO USE
SPOT TREATMENT
To spray small areas or individual weeds, use a pressure sprayer for better
control. Do not use a hose-end sprayer. Mix as directed in table below. Shake
well before spraying. Be certain to wet each weed.
ENTIRE LAWN
PRESSURE SPRAYERS
Measure amount of concentrate from chart below into sprayer tank and dilute
with 1 gal of water. Close tank sprayer and shake well before spraying. Use a
spray pattern that gives small spray droplets without any ne mist to treat
250 sq ft.
HOSE-END SPRAYERS
"CONCENTRATE ONLY" (DIAL) SPRAYERS
1. From the chart below, determine amount of concentrate to be applied for
each 250 sq ft of lawn.
Bermuda,
Bentgrass
St. Augustine*,
Bahia, Centipede
1/2 - oz
2 - oz
2/3 - oz
2 2/3 - oz
1 - oz
4 - oz
1/2 - oz
2/3 - oz
1 - oz
Grass
Type
Ounces in
Sprayer
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
Area
Treated
Dial
Setting
Bluegrass, Fescue,
Rye, Zoysia
FLORIDA.
2. Fill sprayer jar with enough concentrate to cover area to be treated. Do not
add water to sprayer.
3. Set dial on sprayer to the setting from the chart below.
4. Attach sprayer to hose. Extend hose to the farthest area of lawn to be treated
and work back toward faucet so that you do not walk over treated areas.
Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue lawn, add 4 - oz of concentrate to the
sprayer with sprayer dial set on 1 - oz. Check the directions you received when
you purchased your sprayer for further details on the proper use of your dial
sprayer.
"CONCENTRATE-PLUS-WATER" SPRAYERS
For sprayers that require the addition of water as well as concentrate prior to
application:
1. From the following chart, determine amount of concentrate required to treat
2. Pour concentrate into sprayer jar to the required "- oz" level.
3. Then add the appropriate amount of water to the "gallons" level. Replace
sprayer top on jar and shake well before spraying.
treated and work back toward faucet so that you do not walk over treated
areas. Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue, pour in concentrate to the 4 - oz mark
and add water to the 4 gal mark. Check the directions you received when you
Lawn Weed Killers
Apr 18, 2016 | Spectracide Bug and Weed Killer for Lawns...
WHAT IS THE OIL TO GAS MIXTURE IN OIL TO GALLONS
Mixing
RatioGAS:OIL UNITED STATESOIL per 1 U.S. GALLON Gasoline
(128 oz.) *INTERNATIONALOIL per 1 IMPERIAL GALLON Gasoline
(160 oz.) *INTERNATIONALOIL per 1 LITER Gasoline
(metric) 32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
May 04, 2015 | Garden
I have 3 gallons of 44:1 mix already made. How much more oil is needed to make 40:1 and/or 36:1 ... thank you and appreciate your feedback
.Add .87 oz for 40:1 or 1.94 oz for 36:1 to the current 8.73 oz of oil making a total amount of 9.6 oz for 40:1 or 10.67 oz for 36:1.
Required oil amounts
A= 384/44 = 8.73
B = 384/40 = 9.6
C = 384/36 = 10.67
D = B - A for oil to add for 40:1 = .87
D = C - A for oil to add for 36:1 = 1.94
Feb 20, 2015 | Garden
How much roundup do i put in 3 liters of water
Round up is currently offered in a few variations. If you have the "Spray and GO" or the "Spray and Go" refill product do not add water. The ratio is already correct. Likewise for the "Redy-to-Use Plus", do not add water.
If you have the "Weed and Grass Killer Concentrate Plus", the ratio is 3oz/gallon water. 3 liters of water=0.79 gallons so use 2.4 oz of this type of Round Up.
If you have the "Weed and Grass Killer Super Concentrate", the ratio is 1.5oz/gallon water so you would use 1.2 oz of product mixed into 3 liters of water.
If you have a different product and just need to work out the conversion from gallons to liters, 1 gallon=3.78 liters.
Hope this helps.
Dec 31, 2010 | Roundup "" Weed & Grass Killer
Quantity of Roundup weed killer to spray 140 acreas of crop land
This 2.0% glyphosate is ready to apply at a rate of 3-10 gallons per acre That's 420-1400 gallons per 140 acres. Some weeds need a higher concentration than 2%. Most farmers buy 41% glyphosate concentrate, determine the number gallons of spray mixture their equipment will deliver, determine the concentration of glyphosate they need and mix the concentrate with water accordingly.
Apr 01, 2010 | Roundup "" Weed & Grass Killer
Fuel mix wrong, won't fire smokes once in a while
40:1 =40 parts of gas to 1 part oil. If you run 1/4 oz oil to 4 gallons of gas, you will fry a two cycle. That's like running straight gas.
May 26, 2009 | Poulan Featherlite Gas Blower, with Low...
HOW MUCH ROUNDUP TO GALLON OF WATER
regular concentrate 6 fl. oz per gallon
super concentrate 2.5 fl oz per gallon
May 22, 2009 | Roundup "" Weed & Grass Killer
How many oz is 6-2/3 oz
My reference book says 3.78 liters equals one gallon. 3 gallons would be 11.34 liters. 11.34 X 6.66=75.52 oz of concentrate. That is 4.72 pints. A dictionary will have conversion charts.
May 07, 2009 | Chapin Sprayr Home&Garden 3gal 2793 Mfg
Instructions for using ortho tree sprayette
The Ortho Tree and Shrub Sprayette has a fixed mixing jet set to a 24:1 ratio. 5.3 ounces of spray concentrate in the jar will mix to produce 1 gallon of diluted spray. The jar has a capacity of 42.7 ounces, so you can spray up to 8 gallons with 1 filling. If you look at the side of the jar, you will see two filling scales. On the left is the diluted spray capacity, and on the right is the concentrate scale. So you will see 8 gallons opposite 32 ounces, for instance.
You must dilute concentrates to the 24:1 mixing concentration. So if your concentrate says 1 ounce/gallon, and you want to spray 6 gallons, put in 6 ounces and add water to the jar to the 32 ounce level.
Mar 16, 2009 | Garden
Garden Logo
127 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
