Question about HP Pavilion F1903 19" Flat Panel LCD Monitor
Screen lites than goes out - HP Pavilion F1903 19" Flat Panel LCD Monitor
  • 11,361 Answers
Check the DC filter caps (caps with leaking/bulging top), cold solder joints.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jul 11, 2010
My ds lite power gooes off as soon as you turn it on
The bottom screen flashes an then the green light goes off new top screen is needed very common on ds lite i repair them for a living an can sort yours for about 18 quid
Simon
Dsdoc
Nov 26, 2011 | Nintendo DS Lite Console
Tip
DS Lite Top Screen Replacement
Has your top screen devlouped a fault or stopped working altogether? Here is my guide to re-connecting a new top screen and fitting a new one.
Take the DS lite apart (a tri wing screwdriver is needed and can be found cheap on ebay), disconnect the top screen by lifiting the motherboards connector flap (located near the hindge) and then re-insert it, try switching it on again and see if thats sorted it. If not then you will need to replace the screen. (If you need help taking the DS lite apart then check out my other tips and tricks posted on here).
A new screen can be brought on ebay for a reasonable price, there will be a little soldering required as the speakers will need to be de-soldered from the old screen and re-soldered onto the new one (please take note of which wire goes where).
Remove the screws from the lid of the DS lite (4x screws hidden under little coloured squares above and below both speaker outlets) slide the top/outer part away from the hindges, it will move about 5mm and then you can lift it off... Gently pull the ribbon through the hindge so that it is free from the bottom part of the DS lite, pry the screen away from the shell (a small amount of force may be required to remove it) remove the front plastic part of the screen (with the respective DS lite coloured frame, de-solder the speakers, re-attatch them to the new screen, place the new screen into the housing along with the speakers and put back the wifi and mic to their original position if they got moved, you will notice a slot in the hindge where the ribbon goes in, this is for the ribbon to easily slide back into the bottom part of the DS lite... pop the ribbon through and then re-attatch it to the motherboard with the connector, pressing down the connectors flap.
Screw the DS lite back together, after this you will need to place the plastic sheet with the respective DS lite coloured frame back onto the top screen... The reason you don't put it on any time before that is if you put it on prior to putting the new screen in place you will have great difficulty trying to get it correctly aligned.
If you find that your DS lite now doesn't want to stay powered on please refer to my other tips and tricks I have issued on here.
I hope this helps and have to say that I accept no responsability for any damage that may occur to your DS lite when following these tips.
Regards,
SOD69
on Feb 08, 2010 | Nintendo DS Lite
When i plug in my DS lite my nintendo DS lite organe lite to let you know ti charging doesn't come on
it sounds like to me that one of yor screen whent bad when you plug it in it lights orange and goes off for some strange reason when a screen goes the whole thing shuts down i have a guy who fixes my ds's if you are intreasted and he is cheep just send it to jeremy hoffman 4701 carolwood dr greensboro nc 27407 hes on ebay too my not sure of the site he is on its cheep to send only a few dollars and he excepts paypal
Jun 06, 2010 | Nintendo DS Lite Console
Second screen goes on and off, Works for a while
Ok. Maybe you need to charge the Nintendo DS Lite or you might have hit the bottom surface really hard that it hit the touch screen's body in the back.
Contact nintendo, (1)-800-255-3700
or go to:
www.nintendo.com
Mar 06, 2010 | Nintendo DS Lite Console
DS Lite wont power up, just flickers and goes out
ur problem with top screen.the strip may be damaged change the top screen .
Aug 29, 2009 | Nintendo DS Lite Console
Nintendo DS lite; changed touch screen and it won't start
Hi. this issue is normaly caused by bad screen (normaly top screen) or bad assembly in one of two screens, re insert carefully the flex cable again, if your screens are fine this must fix the issue
Mar 14, 2009 | Nintendo DS Lite
Ds lite screen goes funny
your screen is broken.
your ds is like having troubles. like, you have to press the screen a lot times just so it can cooperate, right?
if so, it is.
Feb 13, 2009 | Nintendo DS Lite Console
Top screen goes opaque white, but looks fine with pressed L button.
Puchigusu,
You have a defective flatcable of the upper screen, or the calble is not correct seated in the connector on the systemboard.
The upper screen connector is on the bottom side of the Left button-switch.
If the flatcable is defective (most likely because of the open-close actions every time the DS Lite is used) you have to replace the complete upper screen (the cable cannot be removed without replacing the whole screen).
First try to reseat the flatcable in the connector. If that is not working, replace the screen (manuals how to open the DS Lite etc etc can be found on the Internet)
John
Oct 31, 2008 | Nintendo DS Lite Console
Green light goes on but nintendo ds lite does not boot.
TAKE IT TO A REPAIR SHOP SEE WHAT THEY CAN DO.
Jul 27, 2008 | Nintendo DS Lite Console
My nintendo ds lite top screen isn't working properly
Top LCD's flex cable that passes through right-hand hinge into bottom part of case will be damaged or not properly seated in its connector socket.
Nov 17, 2007 | Nintendo DS Lite Console
HP Pavilion F1903 19" Flat Panel LCD Monitor Logo
87 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
