Question about Lincoln Electric Welding Tools
I HAVE APRO-MIG 110 VOLT WIRE FEED WELDER ok,WHEN I TURN IT ON THE FAN MOTOR RUN'S BUT WHEN i PULL TRIGGER THE WIRE FEED MOTOR DONT RUN i'VE CHECK'T THE MOTOR FOR CONTINUITY AND i HAVE THAT,SO IT ALSO HAS A SMALL PC BOARD ,HOW CAN i CHECK THE DIODES AND OTHER PARTS ,AND ALSO HAS A RECTAFIER AND CAPASITOR ,JUST HELP IF YOU CAN . THANK'S BILLY
I have the same problem! how did u fix it or haven't you?
Posted on Jul 29, 2010
CLarke 130 en everything works Great except when I select # 4 on the heat then it won't feed when the trigger is pulled?
i put a new motor on the welder an i have 9 to 12 vote coming to the motor but the motor wont run all works but the motor
Mar 14, 2012 | Clarke Power Products Clarke 130EN...
It willnot weld
if it is just not feeding wire, check the tension on feed wheel. Make sure it turns when trigger is pressed. Also make sure you have gas with solid wire. If you have cored wire gas is not needed.
Jan 16, 2012 | Clarke Power Products Clarke 130EN Mig 110...
Have a clarke 125en wire feed drive wheels are not turn although it makes the same noise as it did when it worked, it just up and quit
release the tension from the WFR, pull the trigger and check the shaft that the rollers are attached is spinning if yes then the woodruff key is either missing or broken if no then the drive motor needs looking at, the shaft may have broken further along. get an electrician to check it out.
Mar 03, 2011 | Clarke Power Products Clarke 130EN Mig 110...
Wire does not feed motor does not run worked on all connections and it ran for about 4 feet then quit crossed trigger to see if that was the problem and got no wire any suggestions?????
does everything else work? power light come on? fan? does the trigger click? seems like you've tested everything i would have tested. maybe the motor itself. its also possible that theres an open in the wiring to the trigger. i would take the trigger back apart and do a continuity test from the beginning of the wire to the connection in the trigger. check continuity on both trigger wires. the best way to to do that is using a volt meter on either the continuity setting or resistance setting zero resistance or infanite (depending on meter) will mean there is an opening and you will either have to fix it or replace it. if you dont have a volt meter you may also try arcing across the two trigger wires closer to the welder connection.see i had this problem before but it was a faulty trigger so im thinkin if it isnt the trigger (you said you tested it) then its the trigger wiring.
Dec 27, 2010 | Clarke Power Products Clarke 130EN...
I HAVE A HOBART 120 HANDLER WIRE WELDER. THE FAN RUNS AND I HEAR A CLICKING SOUND WHEN I PRESS THE FEED BUTTON ON THE GIUN, BUT THE MOTOR WON'T FEED THE WIRE.IS IT MOST LIKELY THE CONTACTOR IS DEFECTIVE OR...
sounds like the bridge rectifier is bad.to test the motor unplug the motor from unit connect 110 volts to the motor itself and see if the motor runs.easiest way to test motor
Mar 23, 2010 | Welding Tools
My little 110 mig welder is arcing without trigger pulled
i believe that the trigger only send out the wire and does not control the arc the tip should be live as long as the welder is on
Feb 28, 2010 | Lincoln Welding Tools
Wire doesn't feed
Either the trigger mechanism in the gun is bad, the servo that turns the feed wheel is bad, or you have too much tension on the adjustable tensioner knob. Take the wire out of the feed wheel, plug unit in and see if you can get the wheel to turn. If not, it is the trigger or the servo. If it turns, the tensioner was too tight.
Jul 10, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Northern tool mig welder,120 volt with gas.The wire feed is not working.When i pull the trigger the wheel that feeds the wire to the gun does not spin,even with no tension on it.The fan works and the...
you are going to need to remove the wires going to the wire feed motor, then take a volt meter and check the wires when you pull the trigger. this will tell you if the motor is bad or another problem
Apr 14, 2009 | Welding Tools
Welding Tools Logo
215 people viewed this question
Top Lincoln Electric Welding Tools Experts
Troy
Troy
Level 1 Expert
AZBen
AZBen
ka4iup
ka4iup
Are you a Lincoln Electric Welding Tool Expert? Answer questions, earn points and help others
