Question about Microwave Ovens
I WAS HEATING SOMETHING UP IN MY OVER THE RANGE MICROWAVE AND IT JUST WENT "POOF" AND EVERYTHING QUIT.
    Genius:
  • Microwave Ovens Master
  • 1,667 Answers
Obviously something blew in the oven. This will require shop service. It can be anything from the main controler to one of the power supplies.
Jerry G.
Posted on Apr 19, 2008
We have a MH6110XEQ-1 850 Watt built in microwave (manufactured in 1998). I put something in, entered 1 minute, hit start and before the motor engaged everything went "off". Can you suggest a...
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
If the magnetron has failed it is possible that it has taken out the mains fuse. Replace all faulty components with identical types and values!
Hope that helps.
Nov 12, 2010 | Whirlpool MH7155XM Microwave Oven
Microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 15, 2010 | Whirlpool MH7140XF Microwave Oven
It quits heating after a couple minutes and sounds
replace the fan otherwise your microwave cell wil burn out, the safety comes on because the cell become to hot. no colling of microwave cell.
Feb 15, 2010 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Ge spacemaker quit heating everything else works
You megaton went out on you it will cost around 150 to replace it.
Dec 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No heat but everything else works
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Apr 17, 2009 | Whirlpool MH7140XF Microwave Oven
My Kenmore over the range microwave is not heating....
chances are your magnatron quit on you and you may be better off getting a new one.
Apr 05, 2009 | Kenmore 62622 Microwave Oven
Hood range microwave not heating up
We had one that did the same thing. my brother got so mad at it he put a wrench in it and turned it on. It didn't do anything to it. No power surge nothing. It acted as if I put a plate of food. Lighted up turned and even beeped when done. The wrench wasn't even hot. Now I do recommend this myself. But we went and got antoher one.
There is something in there that magnifys the power inside the mircowave and it sounds like its out.
Dec 12, 2008 | Emerson MW8778 Microwave Oven
Just quit working...but not everything.
Hi , open the cover with philips screw driver , b sure unplug it first , If you have continuety tester check the fuse if open replace it , are available in electronics center brings that sample and insert it.
Apr 16, 2008 | Kenmore 62702 Microwave Oven
Open Questions:
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
