Question about Sanyo Cameras
Camera says Lens Error: 0 x 1301 when I try to turn it on.
My Sanyo Digital Camera E1090 is saying lens error 0 1301 what can I do to fix it please
Posted on Nov 17, 2010
Lens error.....restart camera. Tried over and over again. Nothing works. HELP!
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god....
thanks.
Apr 11, 2011 | Canon PowerShot SX10 IS Digital Camera
Canon sd850 is lenz cover partialy closed. Turn on says " lenz error. restart camera. Then shuts itself off.
u have see the user guide if its not help then reset your camera on the factory setting
thanx using fixya i hope it can help u
Sep 06, 2008 | Cameras
Tip
Sanyo digital camera showing lens error 1114 or 112
Hi.
If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
If lens does not retract, try helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
If the camera had been exposed to sand or dust, try blowing canned air on the lens.
If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
Also call the number listed on the owners manual to get support from the manufacturer.
Check also the links below for more troubleshooting in case of lens error:
Lens not retracting on digital camera.
Lens Error.
on Apr 09, 2010 | Cameras
LENS ERROR, RESTART CAMERA...
CANON IXUS 561
Lens sometimes does not extend and error message 'lens error restart camera' appears when camera is turned on. This does not work without several tries and much button pressing. Problem is not caused by finger(s) in front of lens barrel.
May 20, 2010 | Canon PowerShot A560 Digital Camera
Camera felled to floor lens tries but cannot retract camera turns on and off fine, error message "lens error, restart camera" it appears that until lens can function properly and error message is resolved...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 29, 2009 | Canon PowerShot A630 Digital Camera
Canon PowerShot SX 100 IS lens error
Jun 14, 2009 | Canon PowerShot SX100 IS Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Oct 18, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
ERROR 99
if you have a DSLR and your'e getting this "error 99" it may be associated with the particular lens youre using. try turning off the camera and removing the battery, the lens, and the memory card. let it sit for half an hour. reinsert the battery only and depress the shutter button as if you were to take a normal picture. if error 99 occurs again, then the camera needs servicing. if it error 99 doesn't occur at this point, turn the camera off and install the memory card. format the memory card while it's in the camera and press the shutter button as if youw ere to take a normal picture again. if you see error 99, then the problem probably lies with the memory card. if it doesn't occur, turn off the camera and install the lens. again, power on the camera and press the shutter as if you are taking a normal picture. if the error occurs, then it's with the lens. try to clean the lens including the connection points both on the camera and the lens. if the error code still occurs, try different lens to narrow it down to which particular lens is giving the issue. if it happends with all the lens, then the camera needs to be serviced.
Sep 16, 2008 | Canon Cameras
Cameras Logo
211 people viewed this question
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
