Question about Amana ARB2217C Bottom Freezer Refrigerator
Amana bottom Freezer with top refrigerator - Ice maker not making ice - someone didn't shut the door good so I had ice billed-up and turned off to defrost and back on and don't want to make ice.
  • Amana Master
  • 43,501 Answers
Here are some basic tips for ice maker troubleshootingAmana bottom Freezer with top refrigerator - Ice - 2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Jul 13, 2010
4 Suggested Answers
  • 1218 Answers
SOURCE: Amana Refrigerator Model # ARB 2214 CC with leaking ice maker
Good day,
If the fill pipe that fills the ice maker is in it's proper position, then it is a defective water fill valve located in the bottom rear of the machine.
After harvesting the cubes the ice maker mechanism continues to rotate and turns the water valve on for 7 seconds. If it does not shut off smartly then it can cause the well to overfill, and flow water into the bucket.
Do not let this go. A small leak could turn into a major overflow, even overnight causing serious problems to the machine and as I have seen the entire house.
Posted on Dec 21, 2009
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    • 72 Answers
    SOURCE: Our freezer is not cold, food is defrosting, ice
    Look at the back of the freezer wall from inside the freezer. Is there frost on it? If there is, you need to replace one of the components of the defrost system. If there is no frost then you need to have a repair made to the sealed system, it is either out of gas or the compressor is running inefficiently
    Posted on Jun 20, 2009
    My ice maker quit making ice on my amana bottom freezer
    Hi, If your ice maker has stopped making ice then you need to check these things.
    The lever that controls the ice maker has been pushed up which turns it off. If you have a red lever, pull it down to the wire and if you just have a wire then just pull down the wire to start your ice maker up.
    Make sure the freezer temperature is below 10 degrees F If the freezer is too warm ice production will be poor because the ice maker will not cycle properly.
    The ice maker fill tube may have ice formed in it, blocking it. Use a hair dryer to melt the ice. Watch out for the plastic parts, so that you do not melt the plastic. Also check the water inlet valve and the shut off valve, to make sure it is not plugged with debris. The openings in those valves are very small.
    Check the gears in the ice makers to see if they are broken or stripped. Also look to see if the ice rake is broken. All parts in the ice maker are replaceable individually, If you find broken parts replace them.
    Take care
    Jul 23, 2010 | Amana ABB1927DE Bottom Freezer...
    The ice maker in my Amana refrigerator is not making ice. It does not even make any noise
    Good day,
    You'll need to start from he beginning and follow thru. It should solve your problem. It is important that the feezer temperature is normal. Any temperature above 14 degrees will automatically lock out the ice maker, and even at 14 degrees the production would be pathetic. It should be between 0 an 5 degrees.
    First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
    Three possibilities.
    1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
    2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
    If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
    3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
    P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
    Jul 10, 2010 | Amana ATB2136AR Top Freezer Refrigerator
    I have an Amana ARB8057CSR Bottom Freezer Refrigerator and the freezer stoped making ice and there is still water coming out of the tap.
    Good day,
    As long as your sure the temperature in the freezer is within it's normal range, the best procedure is to follow a step by step trouble shooting method to correct your problem.
    May 18, 2010 | Amana ARB8057CSR Bottom Freezer...
    Good day,
    Dec 21, 2009 | Refrigerators
    Ice maker freexes ice together
    maybe too much water going in to the ice maker
    Jun 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
    The auger arm doesn't turn. The ice maker still makes ice, it just can't dispense.
    Take the ice container with auger inside it and defrost it. Withe the door open to the freezer push the switch that turns light on in freezer to turn it off. Have someone push the ice dispenser switch while you hold the light button in. Tell me if there is any movement in the auger motor in rear and let me know what you find. Thanks, Sea Breeze
    Jun 01, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
    Amana Bottom Freezer door when shut starts a noise
    The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
    Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
    Amana 22 side-by-side refrigerator, freezer door opens slightly
    There are three possibilities to this problem:
    1. Door seal which should be magnetic is faulty.
    2. Ice maker caddy (container) has not socketed properly into ice maker rear drive tang.
    3. Door stay closed plastic hing pieces are damaged. These are tapered pieces that fit in hinge area that allow door weight to help close and hold door. Some are black in color and some are white. As far as I know they are interchangeable.
    Jul 17, 2008 | Amana 22.6 cu. ft. Side-By-Side...
    Amana French Door Bottom Freezer
    see if there is any ice caught within the ice maker itself preventing proper cycling of the ice maker. if not pop off the white cover to the ice maker(theres small **** in the cover on bottom right corner of white cover to insert a ***** driver and twist the cover will pop off. look into the center of the main plastic gear, there should be 2 "tabs" holding that gear in place . as if you were to push gear on and the tabs would keep it in place.( reason i mention that it is/was a problem with the ice makers hat the gear would break and it was very noticeable looking into the center gear).if not, theres a detailed trouble shooter for the ice maker behind the kickplate(maybe taped up under front corner under cabinet) it will tell you points to check for power and jump out if necessary
    Mar 12, 2008 | Amana AFD2535DES French Door Refrigerator
    Amana ARB2217C Bottom Freezer Refrigerator Logo
    703 people viewed this question
    Top Amana Refrigerators Experts
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
