Question about ASUS motherboard P5S-MX SE LGA775 SiS671FX Dual core / Core2 Duo PCI-E integrated VGA micro ATX P5... (4719543152454)
When the computer is booting these words appears usb device over current status detected, and then after 15 seconds the computer is shut down
  • ASUS Master
  • 11,800 Answers
A USB device is drawing too much power so the system crashes. Remove all devices attached to USB and try again. If it's the same then remove all external USB ports - the ones connected with wires to the motherboard. If it's the same then there's a short in the motherboard - unfixable, replace it with a new one.
Posted on Jul 10, 2010
When i start my pc i get the error "please enter
One or more of your USB devices connected to your PC are malfunctioned, remove any usb connection exept keyboard and mouse. Boot the PC , if the error still exists then reboot after removing your Mouse first and keyboard at second. Tell me what happens after these.
Sep 14, 2011 | ASUS P5KPL-AM SE Motherboard
Recurring issue: KGPE-D16 opteron 2-CPU "USB
If its forcing a shutdown of the entire machine, I think it may be protecting itself from a voltage issue. What do you have plugged into your USB ports? It sounds like it has detected a voltage problem coming from one of the devices connected to one of its USB ports or something near it and to ensure that the motherboard doesn't get fried its shutting the computer down.
The message is telling you that its detected a device that is over the allowable amount of electrical current and is protecting itself from electrical failure. It could be a problem with the USB jumpers on the motherboard that connect the front usb ports. You might try unplugging these connectors and try to boot up the machine. Leave them unplugged and boot up the machine, if you still get the error after that, it may be a grounding issue with the motherboard mounts that anchor the motherboard to your computer case. If you have any extra mounts underneath the board that you aren't actually using but are coming in contact with the board, you may have to remove them, which would probably involve removing the motherboard from the case.
Feb 13, 2011 | ASUS KGPED16 AMD Opteron Server Bd
USB Over Current Status Detected, Computer will shut down in 15 seconds
this message popped up because one of the device which you connected to the usb of the pc was overdrawing current i.e more than 5V DC. Hence, the built in system security gave this message and will shut down your computer in 15 seconds. In order to avoid this message first remove all the usb items connected to it and then connect one by one and detect the faulty one and replace.
Jan 29, 2011 | ASUS P5PE-VM Motherboard
This is simply telling you that you have WAY too many USB items plugged in.
Your best option is to buy a USB HUB that has its own power supply
Laptops are best known for this issue as they are simply not designed to cope with so many USB devices all at the same time.
Buy a HUB with a power supply you will be glad you did
Bob
Aug 04, 2010 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
System shutdown in 15 seconds
Shut the power down to the computer all the power and pull the power cord out, remove all usb devices except the mouse and keyboard, Turn the unit back on and see if this fixes the problem, if it doesn't then you will have to go into the computer and clear the c-mos this will allow you to get into the bios screen from there you can set up the computer again. Check you manual for the instructions on bios reset, most times it is just pins 2+3 that need to have a jumper installed to reset it. READ THE MANUAL PINS 2+3 APPEAR ON MANY THINGS ON THE CIRCUIT BOARD
May 31, 2010 | ASUS P5PE-VM Motherboard
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
hi, pl check for viruses, scan the system, and go to cmd prompt and issue this commnd at c:\ shudown -a and press enter to disable reboot and scan the system and check any hardware issue.
Aug 12, 2008 | ASUS P5PE-VM Motherboard
Bios setup error
Unplug ALL Usb devices, that includes printers, cameras, pen drives, i.e. anything that plugs into a USB connector. Then try rebooting your computer. I bet your problem will no longer exist, but if it does, then you need to suspect a faulty USB connector on the motherboard or USB chipset located on the motherboard. Once the computer is booting normally without USB devices hooked up, you can start installing ONE Usb device at a time, until you find your defective USB device. The USB device drivers will need to be installed and computer rebooted at least once between the various devices. Not doing so will lead to confusion as to which USB device is causing your high current problem. It is also possible athough a bit unlikely that this procedure will cure your situation for the time being but look out for it in the future because it could be an early sign that one of your USB devices is going bad.
Aug 11, 2008 | ASUS P5PE-VM Motherboard
SYSTEM ERROR
1) if you have nothing in a USB port you will need to set bios
Try removing M/board battery for 2 to 3 hours some people say less then replace it most times it should set BIOS back to default
also check setup of hard disks master slave etc
Last resort with 15 seconds you should be able to see
press ?? key to access BIOS next boot keep pressing key see if that works
Aug 10, 2008 | ASUS M2N-MX Motherboard
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
May 11, 2008 | ASUS M2N-MX Motherboard
ASUS motherboard P5S-MX SE LGA775 SiS671FX Dual core / Core2 Duo PCI-E integrated VGA micro ATX P5... (4719543152454) Logo
295 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
