Question about Philips ProScreen 4650 Multimedia Projector
Slight RGB alignment problem
My Philips ProScreen 4650 has a slight RGB alignment problem. Is there any way I can adjust the alignment? Thanks for any help or suggestion
  • 5 more comments
  • Runnerman May 08, 2008
    Yeah my RGBs are all pointing in different directions causing bars of extra colors on the sides of the picture causing a wanna be 3D look and I have no idea how to fix it.
  • brodytcrouch Jul 04, 2008
    Mine is doing the same thing I attached som pics of it as well
  • JLEMEN Sep 12, 2008
    SAME AS IN THE PICTURES LOOKS LIKE A 3D IMAGE I JUST INSTALLED A 300.00 DOLLAR BULB NO HELP PIC IS LEGABLE BUT APPEARS TO BE OUT OF ALIGNMENT ANY HELP GREATLY APPRECIATED THANKS JEFF
  • blue-mm-guy Oct 15, 2008
    I seem to have the same rgb problem's s the others. The pics posted are identical to mine. When watching a movie or doing powerpoint, everything has a yellow, green, or blue ghost outlining images depending on what side of the screen the image is on(right or left). Is this something that can be fixed myself, or does it have to be taken in, or is the projector junk? Please let me know if anyone has any ideas. Thanks
  • olddiscodj Jan 26, 2009
    Yeah letters and pics are in multiples of three same as the other persons
  • Proscreen Feb 01, 2009
    Yes I seem to have the same problem with red and green ghosting on the sides.
  • cee l dub Feb 16, 2009
    same off alignment as others
We had the same problem, and it seemed to fix itself when we did the following (not sure exactly what it was we did, but it worked):
1) Remove the outer box on the right side (one by the lens), rear, and top. (you'll need a T9 torx screw driver with a long shaft as the first 4 screws are on the bottom under the rubber feet and caps on the front corners of the bottom.)
2) On the top is a board that has 3 orange cables coming out of it as well as some others. We completely removed that board and reinstalled it.
3) We determined that the 3 orange cords control the color out put.
4) So leaving all of the outer sides off, when we reconnected the board and provided power, the image came out properly aligned.
5) We're now struggling w/color. Based on how you insert the orange cords you get different color saturation. We seem to be missing a proper/consistent red display.
6) But the colors are all aligned and the image clear. We're getting there . . . .
Be very careful!!! You could electrocute yourself.
Posted on Jul 18, 2009
This picture can probably show you better than I can describe it;
http://img114.imageshack.us/img114/8957/spa0108pi0.jpg
Posted on Jun 01, 2008
  • 563 Answers
Please describe the allignment problem
Posted on Apr 21, 2008
Convergence phillips proscreen
The adjustment requires disassembling the projector. It's not really something that should be attempted in the field.
Sep 08, 2014 | Philips ProScreen 4750 Impact Multimedia...
Ghosting Image
hi!!!
may be the lens has alignment the lens
of your projector there a adjustment
try to adjust!!!
Sep 21, 2008 | Philips ProScreen 4750 Impact Multimedia...
ALIGN PROBLEM
IS THIS A STATEMENT
OR
PROBLEM
I AM NOT ABLE TO UNDERSTAND
Sep 16, 2008 | Philips ProScreen 4650 Multimedia...
Phlips proscreen 4750, how do i open up the case to get to the inside/ and how do I adjust the convergence?
There is not a lot you can do with it, even setting up the static convergeance as you require a crosshatch generator, dot generator and specialist tools to adjust the LCD immagers.
It is not practical for the laman to attempt an adjustment of this sort.
Take it to a Philips Specialized Repair Centre.
Jan 03, 2011 | Philips Office Equipment & Supplies
Philips Projection Screen TV Model PTV915 Horizontal Alignment
Problem solved, needed to get the universal remote i was using set up with the proper code. Once I did that I was able to use the remote to set up the single & multi-zone Red & Blue Alignment.  I also pulled the back plate off and manually adjusted the RGB focus knobs. It seems to be working just fine now.
Thanks to all the other posts.
Nov 25, 2008 | Philips 50P8341 50" Rear Projection...
HOW CHANGE DE BULB?
On the side you plug everything to.... has 2 screws.remove them ..after completly removing screws..remove cover plate remove the 2 screws holding the bulb housing... you will see a hinged flap pull on this and the whole unit comes out..DO NOT REMOVE IF BULB IS HOT!!!!!
The new bulb comes with a new housing Please do not touch the bulb the oil from your hands will reduce the life of your bulb..Slide the new one in put the screws back, , the cover back and thats it
Oct 07, 2008 | Philips ProScreen 4650 Multimedia...
Colour misalignment and focus
Inside of the tube assembly, there is a cooling liquid. This could be a job to change, and then re-adjust everything. It is also possible that on top of this, there are problems with the convergence and bias control circuits.
Typical repairs can run in the area of about $400 to about $800 depending on the amount of work and type of parts required.
Personaly, I would go out and get a good Plasma or LCD TV at this point!
Jerry G.
May 21, 2008 | Philips 60PP9202 60" Rear Projection...
RGB not aligned so I get thin red vertical stripes displaced to right of icons
If you are handy with allen wrenches, quality screw drivers, and the like, you might 'try' opening up the can of worms and gently manipulating the red LCD panel (it will be obvious--a magenta color when off), by slightly loosening the holding screws, then moving--ever so slightly, the panel untill the ghost disappears. Do not do this though, untill you mark the present position on the top and bottom of the LCD panel. Take pictures, far and close-ups, as you go so you can reassemble the unit. The typically three LCDs can be located by finding the prism cube, located under the circuit board, and just before the output lens. Be patient, and have fun. I did this with an 'out of wack' throw away, and now it is just as enjoyable as my 'dimmer' HDTV projector. Even side by side, from 8 feet away, when both are making 72" images, the HDTV is barely clearer, Jon.
Mar 31, 2007 | Polaroid Polaview 211E Multimedia...
Philips ProScreen 4650 Multimedia Projector Logo
1,470 people viewed this question
Top Philips Office Equipment & Supplies Experts
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
