Question about Samsung YP-U3 MP3 Player
Went in water
It went in water for wahing and now its not working what to do about it
  • 8,596 Answers
Water damage =irreversible = replace entire player
Sorry
Posted on Jul 06, 2008
Why My Samsung wahing machin is spilling water FROM the detergent box
This can happen if your water presuure is too high. The water can splash over the top before going into the drum. Or the channel is blocked and needs clearing. Usualy a simple job
Oct 03, 2014 | Samsung Washing Machines
I have a fisher Paykel IW709AU wahing machine, it does not drain the water after the washing cycle ends, but a buzzing sound starts from the water pump for about 30 seconds and the power cuts out. the...
If you wired the pump directly with a lead and 230V supply and it works ok, then doesn't work when powered by the control board, I would say that there is a problem with the control board not supplying a full 230V to the pump.
Dec 04, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
All of my washing machine's "FUnction" buttons do
Change the program controler unit /the board if you need to get access to all the programs.
Remove the controller unit and make sure that the connectors are tight. Make sure the water level sensors , the door switch is working.
If there is no result the program controller is a suspect.
Jan 21, 2011 | Samsung SW62ASP Top Load Washer
I have a centenial wahing machine that will not fill with water.
check that there is good water flow to the washer, if yes , then it is the selonoid valve on the washer, located inside where the water hoses come in
Oct 20, 2010 | Maytag Washing Machines
Lights come on and the system does not work
it might be your control board,but check the pipe is not bent because that will stop the water flow
Nov 02, 2009 | Kenmore Elite 45986 Front Load Washer
F-01
i went on to the hotpoint website which told me what was wrong
Sep 19, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Water supply
yes it is normal. It fills up during the washing proces
I had the same thought at first but it truns out ok.
Jun 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water
Maybe it leaks from te heating element. Happends often on older Candy machines!
Jan 22, 2008 | Candy AQ130 Front Load Washer
Wahing machine busted
give me the brand and model number so i can know what im dealing with
Dec 31, 2007 | Washing Machines
Samsung YP-U3 MP3 Player Logo
49 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
