Question about GE JBP24 QuickClean Electric Kitchen Range
Stove and oven not heating---display works. no error codes
Hello, We used the stove to prepare dinner last evening. This morning when we attempted to heat breakfast the stove didn't heat. Looking further we noticed that the oven doesn't heat today either. Any suggestions? Thanks MODEL: J BP24G0N2WH SERIAL : GF202161G Hi, My oven was operating normally one day. The next day when I went to turn it on, the light came on normally to say that the oven was on but the oven never heated up. The same problem is present when I tried to turn on the burners; the light would come on saying that they were hot but they actually were not. I unplugged the unit and checked that it was receiving the proper 240 voltage. I also removed the back panel and checked that this voltage was making it into the unit itself, which it was. I have also checked my circuit breakers in my home, which are working properly. Does anyone have a solution to this problem? Thanks!!!
  • 3,037 Answers
You might have some faulty components up in the controller. try dismantle the upper part and check for blown up components or loose connected components and wires.
Please let me know what you find and only work on the oven if you are experienced with working on electronics and are confident in what you are doing.
Thank you for using Fixya and Good Luck on getting this working
Posted on Apr 19, 2008
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
    Brigadier General:
  • 3,614 Answers
Have you check the temp/timer switch of the oven..?
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
Loud pop and light behind stove. Stove top works, oven does not.
Good Morning Stephanie - Typically you may locate the model and serial number in the storage drawer, on the right side. Based on the symptoms you are describing, you may either have a communication error from the main control board or a faulty bake and/or broiler element. If resetting the unit did not solved the issue, at this point I would personally contact a professional to accurately diagnose the range to determine the root cause to reduce the risk of unnecessary parts.
May 26, 2013 | Frigidaire FEF316 Electric Kitchen Range
I have a Maytage electric slide in range with a ceran top. Model number MES5770ACW. I was cooking dinner last night on my stove and the elements on top stopped working. They will not turn on at all even...
Either control board bad, or there is more then one circuit breaker controlling the power, check the breakers on both the inside and outside breaker box...Stranger things have happened..
Sep 10, 2017 | Maytag MES5770 Electric Kitchen Range
What does F13 Error mean?
Here is what the F-13 error code means and the fix for it.
F13 Internal CPU checksum errors 1. Disconnect power for 1 minute.
2. Reconnect power.
3. If failure remains, replace the touch control module
So it says the main computer control had detected a error in the touchpad control
I hope this helps,
Gene
Aug 01, 2011 | Kitchen Ranges
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
Amana Electric Stove Error Message Probelm. PLEASE RESPOND!!!
  • push and hold the clock button for 3 seconds
Mar 10, 2008 | Kitchen Ranges
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
GE JBP24 QuickClean Electric Kitchen Range Logo
168 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
