Question about Jensen PS2180 Car Audio Amplifier
Amplifier making engine noise
Jensen jp
    Problem Solver:
  • 16 Answers
Make sure the remote and power wires are ran on the opposite side of the car from the audio hook ups
Posted on Jul 11, 2010
There's a flashing green and red light when my car is on and the sub attached to the amp is making a heartbeat like noise when the light goes green and then the light goes red right away. everything is...
Check the wires for short circuiting at the car body or speaker wires. Triple check really everything.
Make sure the connectors are 100% connected to the wires. There maybe some resitance if the amp isn't getting enough power from the battery.
Aug 19, 2011 | Jensen JXP680 Car Audio Amplifier
I can not get the noise out of the radio always get that humming sound from the engine like a bad ground
its called motor noise and it is directly caused by the alternator inductively coupling to the audio cables in your car. you need to run the power for the amplifiers away from each other. never run power and audio in parallel to one another make sure any crossings of the cables are at 90 degrees like this ----> +
You could also check your grounds and or add a filter to the system.
Aug 05, 2011 | Jensen VM9312HD Car DVD Player
Where can i get the hi-input plug jensen 600w amplifier? amplifier made by audio-vox, model jpa460, 10 prong socket
You will have to call Jensen. They normally don't come with amps anymore as most users prefer the RCA input for better clarity and sound quality.
Aug 11, 2009 | Jensen 100W x 4 Amplifier KA5 Car Audio...
My sub is making a humming sound
Hey austinpippen,
The noise you are experiencing is due to your rca plug shorting out causing a loop, in outher words, bad earth.
Try getting a noise filter, you take your rca plug and plug it into the noise filter, then wire it to the amp!
you can try a ground loop isolator or relocating your ground [earth].
I hope this helps you out.
Fingers crossed.
Apr 08, 2009 | Jensen A600HLX Car Audio Amplifier
400 watt jensen amp not hitting.
Not to be mean but jensens have never hit as far as i know
Jan 29, 2009 | Jensen LXA400 Car Audio Amplifier
No Audio on Jensen UV8
I just bought the uv8. Ist I must say i hate it, it was the worst purchase made. Amoungst others problems, your answer to solve no audio is this.
<<push mute button>> then volume up. you'll have sound. good luck
Jan 03, 2009 | Jensen VM9510 Car DVD Player
Power inverter blows fuse in car
overloading fuse on cars wiring try direct connection to battery
Dec 27, 2008 | Audiovox Jensen Jp 20 Single Outlet 160...
Jensen xa2150 amplifier
Check and see if its dirty inside, dust and smoke are known to cause problems via shorting or not making contact... sometimes your fuses are a bit over the wall so it would be best to replace them... and check if you have a fuse between your battery and the power cable to avoid over powering the amp
Dec 18, 2007 | Jensen XA2150 Car Audio Amplifier
Help
No. The amplifier gets its signal from the RCAs connected to the "input" jacks, but the "output" jacks are just there to make it easier to add another amplifier. You only need to connect the inputs for the amp to work.
Jun 29, 2007 | Jensen A600HLX Car Audio Amplifier
Jensen Amplifier..4 x 50WRMS at 4 Ohms
This sounds like you need a ceramic noise suppression filter/ferrule on the Power line to the amp. You should be able to get a suitable one from most car audio shops. Hope this helps, please post again if you have trouble getting one :)
Mar 28, 2007 | Jensen A600HLX Car Audio Amplifier
Jensen PS2180 Car Audio Amplifier Logo
53 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
