Question about Canon imageCLASS MF6550 Monochrome Laser Copier
How to fix paper jam
Paper got jammed every time I make copy,unable to use copier anymore
  • 1,219 Answers
Where do you have paper jam?
i.e. in fixing assy, in cassete, in duplex, in...
Please be specific, with these information I can only tell you to clean rollers.
You can also contact me on emma.servis@gmail.com
Posted on Jul 11, 2010
  • margie_ise Mar 23, 2011
    fixing assembly
    duplexor
  • Canon tech CROATIA
    Canon tech CROATIA Mar 24, 2011
    OK, its probably plastic sensor flapper. It has spring, that "moves" the flapper in "home" position. Use WD40 or similar and spray it on spring, few times move the flapper manually.
    When You open fixing cover, you will see "nose" in the middle, that is sensor flapper.
    Hope that helps!
How do I fix my Utax CD 1315 every time it makes a copy J40 appears in the window and won't make anymore copies
J40 is a paper jam might be a pickup roller check complete paper path might also be a hung exit sensor
Sep 16, 2016 | Office Equipment & Supplies
Unable to copy code h5 01
Cause: Paper jam in fuser unit or paper jam removed beyond required time.
solution: remove jam from fuser unit.....perform simulation 14 to reset machine!!!
Feb 23, 2011 | Sharp AR-407 Copier
Keeps showing follow instrctns in right cover to remove. Unable to copy
ther is a paper jam in the machine, open the side cover and remove the paper jam, if the paper is not visible then there is a small piece stuck somewhere.
Nov 17, 2010 | Ricoh Aficio 2015 Copier
After making a lot of copies- Dialta 3010 copier jams every time
you probably need you fuser rebuilt. the heat roller melts the toner into the papew. it is covered in teflon. over time the teflon wears off anf toner sticks to it causing paper jams when the copier gets hot
Dec 30, 2009 | Konica Minolta DiALTA CF910 Copier
Copy turns on but unable to make copy
Hello sir;Check the paper tray, pull out paper tray may be have a paper hanging there.
Jun 13, 2009 | Canon PC-920 Black and White Copier
Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
Apr 28, 2009 | Kyocera Copystar CS-1820 Black and White...
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Copier - Paper does not feed/paper jam light keeps going on.
Depending on the type of machine, it is probably just dirty rollers that pick up your paper (slipping). If you remove the tray, and look inside you should see some rollers (usually gray) that take the paper from the tray. Use a cloth dampened with some alcohol(if you have it) or simply water to clean these rollers (gently).. dry if you have used water, the top sheet or 2 of previously used paper, and try it.
Jan 23, 2009 | Office Equipment & Supplies
Change papaer size and frequent papaer jams
OK it seems to be a problem with pick up clutch and vertical feed rollers ( When you open the left door and hinge in level of cass you will see axis with the tree little rollers- clean it with alcohol or water).Pick up clutch is better to replace it FK2-1068 (europe code).
Jan 12, 2009 | Canon iR 2016i Black and White Copier
Red light on Printer doesn't want to print anymore
pull out the cartridge and look for paper inside, re-install cartridge, also look on the back part where the fuser and exit assembly is look for paper jammed. also make sure the paper is set correctly on the tray.
Jan 06, 2008 | Brother HL 1430 Laser Printer
Canon imageCLASS MF6550 Monochrome Laser Copier Logo
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
