Question about Amana ATB2136AR Top Freezer Refrigerator
The ice maker in my Amana refrigerator is not making ice. It does not even make any noise
    President:
  • 1,218 Answers
Good day,
You'll need to start from he beginning and follow thru. It should solve your problem. It is important that the feezer temperature is normal. Any temperature above 14 degrees will automatically lock out the ice maker, and even at 14 degrees the production would be pathetic. It should be between 0 an 5 degrees.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on Jul 10, 2010
Amanda side by side refrigerator ice descender making clicking noise no water hooked up annoying
Even though there is no water connected, you will probably have to turn the ice maker unit to OFF so it stops trying to harvest... If you are never going to use it, simply remove it by taking out the one 1/4" nut screw on the bottom and the two screws above the unit, then unclip the wire harness. It will give you more room and cease the endless clicking... Amana Ice Maker Assembly D7824706Q
Jul 05, 2016 | Refrigerators
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
Ice maker did not produce ice, then it started to
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 24, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Amana bottom freezer, model abc2037dts, there is a motor noise that goes on for 8 seconds then shuts off, then a few clunks for 2 seconds
Even if you do not have the water hooked up for the dispenser and ice maker, the fridge still makes the sound as if it is filling up the ice maker. If you lift the metal arm beside the ice maker, the sound stops happening because it thinks that the ice bucket is full.
Aug 08, 2010 | Refrigerators
ICE MAKER MAKING NOISE BUT NOT MAKING ICE
What sort of noise?. If it's a buzzing noise, it could possibly be the hot gas solenoid is still energised, thus defrosting the ice frame.
Apr 17, 2010 | Amana AFD2535DES French Door Refrigerator
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Ice maker will not make ice, water dispenser is working
heatman101
oypyiooiyp
May 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker
replace micro switch above the ice maker lever in the dispensor housing
Jan 22, 2009 | Amana ARS2464B Side by Side Refrigerator
Amana ATB2136AR Top Freezer Refrigerator Logo
124 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
