Question about Sony MHC-RX100AV Shelf System
Sony MHCRX 100AV 1997 Model
My stereo is having a problem, the main power supply keeps having a shortage and the fan does not come on automatic. What should I do about this problem?
Cooking a roast in small oven last nite, all electric went, oven tripped it. Now no top oven working or main oven or fan. What has gone wrong?
When the mains fuse keeps tripping as soon as you switch on the oven, there could be a shortage in the oven, or some of the voltage is leaking to the ground. What it is causing it? I would not know. sorry.
Mar 24, 2015 | Ovens
Trying to driveRHEEM RAMB-036JAZ using a Honda eu2000 generator. How to hook this up?
You have to very careful powering up home appliances on portable generators due to back feed problems to incoming lines. I would recommend getting an experienced electrician to show and explain the problems with what you are considering. Many linemen have been shocked due to backfeed. The real way to perform this is to get the controller that is put on home generating systems such as generac type systems. These automatically isolate line supply from backup power from home generators, thereby eliminating shock hazards to linemen.
If prolonged shortage, you could disconnect the wires into the furnace and install an extension cord from the furnace to the 120 volt plug on the generator. Most fans are powered on gas furnace on 120 volt. Make sure your voltage needed on your furnace before attempting emergency power up. I have seen some furnaces power by 240 volt fan motors. If it is 240 volt then use the 240 plug wired correctly. PS when you get an electrician to help you with the wiring, check out the requirement to provide grounding, to lessen your shock hazard.
Hope this helps.
Dec 19, 2014 | Heating & Cooling
Fuse keeps popping on my technics stereo receiver. Model sa - g x 6 90 ...wut s wrong ...????
Be sure speaker wires are not shorted together. If fuse is the main power fuse, the power supply has a bad diode.
Nov 08, 2011 | Technics Audio Players & Recorders
Hi, my sony plasma KEP42M1 keeps switching off and on automatically especially during the first hour run, apparently common problem with this model cause also a friend of mine has the same problem. Can you...
its a problem with the onboard power supply it needs to be replaced. im sorry for the bad news hope that doesnt mean a bad rating for me.. you can try to reset the power supply by keeping it unplugged for about 20 minutes.
-brian
Mar 17, 2011 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Hi our Sony wega keeps switching itself on and off sometimes it gies a day without doing it and then sometimes it does it every 5-10 minutes model number is KLV-L32M1??? any ideas?
Try this temporarily-
Position a portable fan toward the rear of the unit aiming it at slots in the rear housing.
If this causes the set to stay on longer, you probably have some cheap capacitors in the main power supply that are failing and will need to be replaced.
Nov 24, 2010 | Televison & Video
MAIN INPUT FUSE KEEPS BLOWING
theres a shortage in the circuit try check the rectifier diodes at primary power supply section, not dangerous to little knowledge,refer to a qualified service technician
Jan 03, 2010 | Samsung TXP3275H 32" TV
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Intel 210882 mother board power won't spool up fans or anything.
usually power supplies comes in different voltage n wattage . check ur mother board manual that which type of powre supply it support than replace it with the good one.it may solve ur problem.thanks
Apr 17, 2009 | Intel Motherboard
Sony Liv Clock Radio, Cd Player
I have a sony dream machine ICF-C18 and had day light saving time and cannot change the time
Please help
Jun 17, 2008 | Sony Dual-Alarm AM/FM Clock Radio with...
66 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
