Question about Uniden Cordless Phone
Power Max5.8ghz One of my 3 phones does non work .When I turn it on connecting flashes and then out of range comes on.
  • russ3 May 10, 2008
    I switched batteries in two phones and it started working.
  • sabuandangie Aug 07, 2008
    my phone keeps saying out of range.
    I tried the deregister hs and still says out of range
    Genius:
  • 1,224 Answers
Need to reset phone pound # key and i believe its the phone answer off button hold those down together deregister the phone and then when done there place back on base to reregister phone it does it automatically
Posted on May 10, 2008
Non runner on 2013 Eclispe Mobilioty Scooter, red light flashing.
U HAVE TO PUT +61 IN FRONT OF NUMBER TRY THIS NUMBER IN STAFFORDSHIRE 01543 570341 THEY M HELP IGHTI just rang this number & it rang 0249624007.Found this scooter repair in Newcastle contact Peter walz,02 4962 4007 Hi again ring this number they can help u with youre problem 0403 666 613..…,or 1800 726 000. good luck. check all connections between motor & controller 2 flashes,,3 flashes motor has a short circuit to a battery connection contact service center,..,.cheers
Sep 12, 2016 | Health & Beauty
Why does it drain while charging?
It's possibly a fault in your wall adaptor or cable -- the phone is burning more energy than it is taking in, possibly because the phone believes it's in PC connection mode or non-standard charge mode, which prevents it from drawing full power.
Aug 03, 2015 | LG Nexus 4
How do I link handset to base after power outage CS6529-3
You set the cordless phone back into the charging base. After a few seconds (longer if in need of a charge), the cordless will register with the base establishing the connection required to place and receive calls.
Feb 19, 2015 | Lands Phones
I am pretty sure that the numeric passkey for Jabra BT2070 is 0000 but it doesnot work in my blackberry 8900. how do i connect it to my phone ?
Try this... 1. Turn off the Jabra bluetooth. 2. Turn on by pressing Volume up + power button until the power light comes on steady. 3. Then turn bluetooth from your blackberry 8900 and make the bluetooth seen/available by other devices. 4. Search bluetooth in range...Look for Jabra BT2070 click then will ask you to put the code which is "0000" or "1234". 5. Then check if the steady light comes to blink...
Mar 19, 2011 | Cell Phones
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
Clear the Handset's Base Data
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
Note: This requires that the base and handset can communicate with each other.
Clear the Base Handset Data
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
Nov 12, 2010 | Uniden Lands Phones
2005 Range Rover HSE - Random Radio / CD Problems
I have an 05 hse with the same issue, prought it to an electrical specialist who went in the boot and unkinked the infrared wires from all components, it worked for about a month and a few days ago it started again,when you say you "deoxed" the bluetooth harness....do you mean the nokia brain in the left rear boot or the cell phone dock in the front center console??? I have an appointment with the dealership tommorow and i hope they find the WIRING issue instead of trying to have me buy $5000 in new computers that wont fix the problem,its a common issue in this model with the logic 7 just wish someone who has already cleared this hurdle would post a solution:(...I will keep everyone updated
Aug 21, 2009 | 2005 Land Rover Range Rover
Bluetooth not powering up
Try this ::
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life. 2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is sually provided by the Bluetooth device manufacturer, not the RAZR. Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
PLEASE DONT FORGET TO RATE THIS RESOLUTION.
Nov 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Mar 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Uniden Cordless Phone Logo
113 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
