Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Dishwasher will not turn on. We think the start button is the problem, having checked everything else we could think of. We cannot find the manual. The light on "clean" keeps b;inking as well, but there is no button for this.
  • 10,515 Answers
This is a common problem.
Read :-
http://servicematters.com/clean_led/8178496.pdf
You need to have an Acrobat Reader to view this file.
Take a look at the Video :-
http://servicematters.com/clean_led/blinking_video_body.htm
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 10, 2010
How do i start the cycle
Short of getting the manual, you will have to figure out by trial and error each button- most importantly the start. Then one by one chart the location and function of each button and when satisfied, mark them on the d/w with indelible ink.
Dec 13, 2013 | Smeg DWI614 Built-in Dishwasher
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Control panel will not light up, the dishwasher was running and now it has stopped mid cycle and will not do anything. I just replaced the control panel (black plastic with buttons, not control...
I have a kitchenaid dishwasher model # KUDC10FXBL1 I went to start it and none of the buttons were working. I have checked the breaker and the wiring and everything seems to be in order.
Jan 13, 2011 | KitchenAid 34 in. KUDP01FLSS Stainless...
Maytag dishwasher mdbh945aww3 does not start washing. the only button that seems to work is the start/cancel and all it does is turn on all the lights.
you have to get the touch pad replaced. my worked for 11 month, got it replaced (3 weeks to get the part), worked for 1.5 month and broke again out of warranty. time to get a new dishwasher and extended warranty. maytag is total c$%p. Everything is made in Mexico. I think even China makes a better product. WOW did I say that?!?!
Jun 27, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Dishwasher won't start and control buttons don't do anything.
It would have helped if you provide the Dishwasher model.
HOwever, I am assuming you have the power connected and inlet water is turned on.
It is likely the child control button might be enabled. CHeck dishwasher manual to show how to disable child lock.
If this is not the problem, then assuming your dishwasher has this feature, try to hard reset the dishwasher to factory setting. This is usually done by pressing 2 buttons (depending on dishwasher) together for a specific time. Or in some cases the mains power is turned off and on within a specific time.
Please post a comment to indicate your observations and model no. Please do not rate this solution until I have got some more details of your dishwasher problem.
Jan 17, 2010 | GE Dishwashers
My GE dishwasher, when i push the start button nothing happens.
1)check any fuse had gone in electronic board.
2)check the input voltage to pcb.(normal)
Jan 08, 2010 | GE 24 in. GSD4000J Built-in Dishwasher
Bosch Dishwasher will not power on
I saw my repair man do the following, which you might try...
Open the door and simultaneously press & hold down the power button with the 2 buttons used on your model to "Cancel & Drain." If the unit comes on it now is in self-diagnosis mode. Release the buttons and close the door. The unit should start to fill with water. Press the power button to exit the mode.
Jun 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
I have a Kenmore Elite Ultra Dishwasher and the cleaning light is flashing. I have tried pressing the start/resume button and closing the door within 3 seconds. I am not able to turn on my dishwasher. I...
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 02, 2009 | Dishwashers
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Nov 02, 2007 | Miele 24 in. G646SC Plus Free-Standing...
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
155 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
