Question about Nintendo Wii Console
Not conecting to internet
There is a eror with code 51331
please help
  • 864 Answers
Try this. This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Posted on Aug 27, 2010
On the wii eror code 51331
It just means that you entered the wrong password for your network. Retry your password, it's case sensitive. If it's still not working and your sure of the password, unplug your router/modem/wii for 30 sec and retry. If it's still not working it might be due to radio interference try changing the routers channel settings to a different channel (default 6, range 1-11).
Jul 06, 2011 | Computers & Internet
I keep getting an error code 51331. cannot get an internet access on my wii
The link below will go over error 51331 and how to resolve it. This error seems to be caused by a network configuration issue.
Click Here
Regards,
G33k
May 10, 2011 | Nintendo Wii Console
How do I get my Wii to connect to my internet wirelessly? When I try I get error code 51331
Sorry to hear you are having problems with your wii. According to Nintendo, error code 51331 is:
Error Code: 51331
Unable to connect to your wireless network
This error code is more specific to having incorrect security settings on your wii. Your encryption key is wrong when trying to connect to your wireless internet. Double check your encryption key with your router's settings and try again.
You can see the official support article from Nintendo here:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51331&system=Wii&locale=lang
Apr 27, 2011 | Nintendo Video Game Consoles & Games
Will not connect to internet error code 51331
Hi there, Error code 51331 means that there is a problem with the security key on your wifi connection. You will just need to through the setup on your console again taking care that you enter the security key the wep/wpa key on the back of your router exactly as it is(ie. Small letter, capital letter, number etc.) hope this helps
Jan 21, 2011 | Nintendo Wii Console
In geting eror 51331
hi there,
error 51331 means there is a problem with your wifi security details. go through the wifi setup again and make sure the wep/wpa key on your router matches what you entered on the wii during setup. Hope this helps
Jan 19, 2011 | Nintendo Wii Console
Keep getting error code 51331 canot conect to internet
There are series of problem in Nintendo wii which can be solved without much technical knowledge........ Your problem belongs to that so don't worry i will give you the link to download the Nintendo repair guide that will help you a lot...
Click here to download Ninento wii repair guide
Jan 05, 2011 | Nintendo Wii Console
Error code 51331
If you got error code 51331, this basically means you can't connect to the Internet because of wireless interference.
Try these:
Move your router away from metal objects such as metal cabinets, and place it in a central location in your home.
Do not use other wireless devices while trying to connect to the Internet.
Avoid devices that use a 2.4GHz radio frequency. Look for devices that use a 5.8GHz or 900MHz frequency.
Change the channel on your router to 1 or 11, as these don't overlap.
If you have encyrption on your router, make the WEP/WPA key is correct.
Change the mode on your router to "mixed" or "b/g" mode.
Hope this helps!
Sep 25, 2009 | Nintendo Mario Kart (Wii) for Wii
Error Code 51331
Wii Error Code 51331 means there is a problem with wireless security.
Make sure your router’s WEP key matches the WEP Key you entered in the Wii.
If your router is using 64-bit encryption, the WEP Key must be 10 characters.
For 128-bit encryption, the WEP Key must be 26 characters.
WEP Keys can only use the characters 0-9 and A-F.
If your router allows more than one WEP key to be entered at a time, make sure the key you’re using is on slot one.
If you double checked the WEP or WPA key with the router and the Wii and they match, but you still receive the Wii Error Code 51331, then MAC filtering may be enabled in the router. You will have to add your Wii’s MAC address to the router’s allowed list. You can do this by logging into your router and going to the “access control, access list, or network filter” settings.
If you still have trouble with Wii Error Code 51331, try changing the wireless router’s channel to 1 or 11. This may increase download speed.
Check Nintendo’s router page for special notes on your router if available. Follow the instructions of the special notes.
Your wireless router must broadcast in mixed or b/g mode and cannot be set to “g” only mode.
If you still encounter the Wii Error Code 51331, try doing manually setting up the Wii’s internet connection. You can find your network information to enter into the Wii by doing this:
On your PC, click “Start” and then “Run.”
Type “CMD” into the field that appears to open a new window.
Type “IPCONFIG/ALL” and press “Enter” to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle the wireless router and modem by unplugging both from the wall. After waiting a minute, plug the modem back in and wait another couple of minutes for the modem to initialize. Plug the router in and wait for the router to initialize. Now try reconnecting the Wii to Nintendo WiFi Connection.
Hope this helps a little
Sep 10, 2008 | Nintendo Wii Console
Internet conection for wii
· Here is a Video on how it is done, if you have done this... i believe it would be the settings on your computer.... are you able to set settings on your switch?
YouTube - How to setup a Nintendo Wii USB Lan Adapter (Remix version)
· http://www.youtube.com/watch?v=FP0qnxD9u-8
Feb 06, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
20 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
