Question about Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit
My bostitch framing nailer is leaking alot of air through the trigger
    New Friend:
Your nailer most likely uses a trigger, and the best place to purchase a new trigger is amazon. Take a look on this link Bostitch TVA11 Trigger Valve Kit I hope this was helpful. cheers
My bostitch framing nailer is leaking alot of air - bostitch-framing-nailer-leaking-alot-air-atj332yoy54aaiam5221rt21-2-0.jpg
Posted on Nov 28, 2014
    President:
  • Stanley Master
  • 1,388 Answers
Your nailer most likely uses a trigger valve part # tva6 (cost about $25) and is sold at www.bostitch.com or ebay for generic. If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body (Use punch for 3mm hole). Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. Note the two grooves on the side of the valve where retainer roll pins hold valve. Remember to insert the valve with these two groves aligned with path of roll pins. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring/seal on plunger is cause of leak. Try using an oring with smaller inside diameter than the broken or loose fintting seal that is present. It must fit pretty tight and be slightly thicker than 1/16" to work (metric 5.3 x 2.5 works). Remove the outer orings to valve and clean and re-use same. Clean the valve port in body of gun and check for sharp edges to prevent cutting orings before inserting the valve. Use silicone lube or oring lube on the orings and the valve port (Danco silicone paste sold at Lowes in the plumbing department). Good Luck on your repair and email if you have other questions
Posted on Jul 11, 2010
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: I need help replacing a bostitch framing air
follow closely, do you have a new trigger assembly because the problem is with one o ring commonly referred as the purple o ring in the kits? either way the procedure to remove the trigger is first knock out the roll pin for the trigger latch and then the 2 roll pins for the trigger assembly. next get a shop rag or equivelant and place under the now exposed trigger assembly and then while holding the collar on the air chuck plug into tool and hold rag tight and trigger will "pop" out pull the chuck away and remove the 2 pins to disassemble the assembly or install in reverse order lubricating the o rings first. Let me know if you have any questions or problems.
Posted on Nov 24, 2009
N88 bostitch nailer fires when connecting air hose
I have seen this on dewalt nailers also, caused by trigger valve worn. on Bostitch nailer part # tva6 remove roll pins retaining trigger and trigger valve. one roll pin for trigger and one or two for valve. With pins removed apply air pressure to gun popping out the valve. Use glove or folded-up shop rag to catch the valve as I pops out. Be sure to reduce air pressure as it could come out with force. Good luck
Jan 20, 2014 | Stanley Bostitch Coil Framing Nailer
N88rh bostitch nailer fires first shot without trigger depressing
Worn orings in the gun and the trigger valve will cause the gun to fire upon connecting the air. It is a good practice to remove the nails when you remove the airline until you can replace the trigger valve. I believe that you gun uses a TVA6 valve. It should be replaced when it begins to leak or if the trigger pin seems loose and rocks from side to side. Factory valve costs about 25 dollars and aftermarket sells for about 12 to 18 dollars. Good luck
Jan 20, 2014 | Stanley Bostitch 28 Industrial Framing...
I have a Bostitch coil framing nailer M#N80CB-1 which was working fine one minute, than after setting it down for a minute it is leaking air under the triggger and will not fire after the first nail.
Air leaking at the trigger is caused by faulty orings in the trigger valve. You could replace the orings in the valve or replace the whole valve (not expensive on ebay, look for generic tva6 valve usually less than $20). Good luck
Nov 30, 2013 | Air Tools & Compressors
My bostitch n63cp coil framing nailer blows air continuously near the trigger and does not shoot the nail. What is wrong and how can I fix it?
Replace the trigger valve assembly. Part TVA6. It takes just a few minutes. The part will include a pin punchout tool, you supply the hammer.
Jun 28, 2010 | Stanley Bostitch Coil Framing Nailer
N64C GUN HAS A LOT OF AIR COMING OUT OF THE TRIGGER. HOW DO I FIX IT?
This can be caused by a defective o-ring or a trigger. Repalcemetn parts aer available here:
http://www.mastertoolrepair.com/bostitch-n64c-nailer-p-20071.html?osCsid=hl63q31pjjkg5c34jks4im8lh2
The trigger assembly is part # TVA6 and costs $20.
Hope this helps,
Dan
May 19, 2010 | Stanley Bostitch N80CB Coil Framing Nailer
What causes air leak around trigger and loss of compression on bostitch on n79ww modelframing nailer
Are you using air tool oil fairly frequently? Any rubber "O" rings will wear rapidly if not lubricated properly.
Jan 01, 2010 | Stanley Bostitch N88rh Framing Nailer...
I need help replacing a bostitch framing air nailer trigger model 28ww it's leaking air and won't work.
Nov 22, 2009 | Stanley Bostitch F28WWMCN 28° Industrial...
My framing Bostitch air gun , model N95RHN blows
prolly clogged, buy a rebuild kit and use it making sure all parts are totally clean before reassembly. in the future be sure to drain your compressor at least daily after use (more on wet or humid days) to avoid this
Nov 14, 2009 | Stanley Bostitch Coil Framing Nailer
Framing gun not firing leaking air aroung trigger
You have a crumbled trigger seal. You can order a new trigger valve through bostitch. It usually takes a couple of weeks though.. Every time I order one it is on backorder. You will need to order trigger valve kit part number TVA11 $21.40. Go to the Bostitch website click on Schematics and Parts to the left then find your model nailer in the search field and select item 53 when the parts list comes up. Click add to cart to order. Another screen will pop up and ask you if you want to checkout. Any questions please post back.
Oct 15, 2009 | Stanley Bostitch N88rh Framing Nailer...
Constant air leak
Sounds like you need a repair kit or take to a tool company that installs the kit.
Jun 09, 2009 | Stanley Bostitch Coil Framing Nailer
Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit Logo
4,066 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
