Question about Mitsubishi WS-65809 65" Rear Projection Television
Picture will not come on. I get menu and a blue screen when I change componets with the remote controller. Now the TV will turn on then turn itself off within 2 seconds.
  • 10,515 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input/or device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
Let me know,so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 10, 2010
  • 2 more comments
  • rainemich564 Jul 10, 2010
    the code was 2 binks then 3 blinks
  • taran_2005
    taran_2005 Jul 10, 2010
    Thanks for your response!!
    Hmm, well that's not great news. A 2-3 error code indicates a problem in the horizontal deflection and high voltage circuits, and is a fairly uncommon problem with this TV.
    What you need to do is pull off the speaker grill, and remove the access panel behind the speaker grill. Get a flashlight and look carefully at the 3 circuit boards near the front, under the tubes. There have been problems where cooling fluid from inside one of the tubes has leaked out. If you see any fluid on the right most PC board, most likely your set is trash. If you see any on the middle or left boards, it may be able to be fixed.
    Of course, there are many other problems that will cause this error code, and if you have electronics experience and (ideally) an oscilloscope, I can give you some ideas. You'd also need a service manual.
    Otherwise, you will have to call a Mits tech.
    Proceed.
    Hope i helped you.
  • rainemich564 Jul 11, 2010
    I can not see any fluid leakage on any of the circuit boards.
  • taran_2005
    taran_2005 Jul 11, 2010
    Then, it is almost certain that it is an issue with horizontal deflection and high voltage circuits. Do you have the schematics??
    It would be dangerous to play with horizontal deflection and high voltage circuits even though the TV is unplugged. I would be able to provide you few pointers, however you need to have experience on working on these sets.
    If yes, revert and i would be able to give you some directions.
    Let me know,so that we could proceed.
    Hope i helped you.
Screen keeps changing colors and will not show picture
hi is it flashing red blue green, if so the tv is in screen burn mode, just press menu on the remote retune the tv, what is the model number of the tv you may need to go into the service menu turn screen burn mode off, thanks
shaun
Feb 25, 2017 | Televison & Video
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
Cannot change the picture back to full screen. remote control want return the picture to full screen with the
Hi, Turn your TV on, select the menu and see if there is something in picture settings (wide screen or full screen) Try to connect a DVD player using HDMI cable. See if there is any difference.
Some DVD players will also have screen sizing. If nothing helps contact TV repair. Good luck
Jul 24, 2011 | Hitachi CLU-5713TSI Remote Control
We need the device code of the panasonic Tc42px24 plasma HDTV thank
Hello
Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
following remote control sequence:
-select the SET-UP icon and select CABLE mode.
-select the TIMER icon and set the SLEEP timer for 30 minutes.
-press the ACTION button twice to get out of the menus.
-change to channel 124.
-adjust the volume to minimum (0).
-Hit the VOL down button on the TV itself (not on
the remote) and a red "CHK" should appear in the upper corner.
-press the ACTION and VOLUME DOWN buttons (again, on the
TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
Select Serviceman mode. The POWER button on the remote control will
select one of the five Serviceman Adjustment modes.
The modes are:
B - Serviceman VCJ SUB Adjustments. These include sub-tint,
sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
audio and video adjustment, and vertical size.
C - Serviceman VCJ Cut-off adjustments. These include Red, Green
and Blue cut-off, red and blue drive, automatic fine tuning
(AFT), RF AGC (RF gain control), horizontal center, beam limit,
etc.
S - Serviceman Options Adjustments. These involce the PIP and
clock.
M - Serviceman MTS (Stereo/SAP) adjustments.
CHK - the mode you first entered. Normal picture and sound, lets
you check things over and still have a hotkey into the
service menu.
There is one more adjustment that isn't in the five modes, it's
global. When in either the yellow or red CHK mode, you can press
RECALL on the remote control to enter the purity field check mode.
This lets you select a pure white, red, green, or blue screen. A
good thing to walk away from if you just want to temporarily freak
out the floor manager, but it will be fixed as soon as the TV is
turned off. Oh well.
To get out of Serviceman mode, press ACTION and POWER on the
receiver simultaneously for at least 2 seconds. The TV will momentarily
shut off and then comes back on.
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
* Hold down the {VOL -} button ON THE PLASMA TV.
* Press the {RECALL} button 3 times on the remote.
* The Service Menu will be displayed.
* Use {1} {2} on remote to navigate main menu items.
* Use {3} {4} on remote to navigate sub-menu items.
* Use {VOL+} {VOL -} on remote to change item value.
* Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
* Power off to exit service mode and save
OK.
Feb 13, 2011 | Panasonic Tc42px14 42 in. TV
When hooked directly to cable, I get a blue screen and sound. When hooked to Componet Video, S- Video, or Composit Video via a cable box, I get a picture and sound. Apex remote will not change sound or...
your cable box rf pass through may be turned off if you can access the menu of the cable box by turning it off and hittiing th emenu button on the cable box with tv on an scroll down to rf out if you need hael call your local cable company
Nov 19, 2009 | Apex Digital AVL2776 27 in. HD-Ready LCD...
Blue menu screen stays on
Hi! the blue menu screen can be turned off by pressing the same button that caused it to appear. In most cases pressing the "Menu" button on the remote or TV-control will make the blue menu screen disappear..
I hope this helps!
Mar 10, 2009 | Zenith C27A24T 27" TV
TV turned off itself
Can you still turn it on?
If so, does it stay on with sound?
If the sound is ok and the picture is blue (even when changing channels, inputs, etc.) the lamp may have gone out.
Can you see the TV menu when you press the menu button on the remote or TV?
Jan 07, 2009 | Sony KP-51HW40 51" Rear Projection...
Grey Screen
Try the reset on the remote. Press this key twice to restore factory settings. The TV will automatically start Channel Search and clear all customized settings. These features will automatically reset: ? Picture/Sound Adjustments: Color, Tint, Contrast, Brightness, Sharpness, Color Enhancer, Tone, and Surround Sound ? Channel Memory ? Audio to Stereo ? Caption to OFF ? V-Guide to OFF ? Aspect Ratio to 4:3 (normal) ? Menu Language to English ? Sleep Timer (if previously set) ? Video to TV (if previously set) If desired, personal settings can be made again using the menu options
Jun 23, 2007 | Sanyo DS32224 TV
Mitsubishi WS-65809 65" Rear Projection Television Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
