Question about GE Spacemaker JVM1640SJ Microwave Oven
Light not turning off
The light is not going off when i press the button. how do I make it go off now?
  • GE Master
  • 9,085 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 11, 2010
Oster microwave starts when door is closed but no buttons pressed
This is usually caused by a door switch that has come loose or out of adjustment.
Jul 19, 2014 | Oster 0.7 Cu. Ft. Countertop Microwave -...
Sharp r-530ek-t on pressing start does not turn light is on
The bottom door switch is defective, or its mount is loose, misaligned, or broken.
Replacing it's not a difficult DIY job.
The service manual is here. My help file on door switches is here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 27, 2017 | Sharp Microwave Ovens
My microwave GELX1800 is not heating... when the express button is pressed it opens the vent lid and the plate turns around but is not heating. The vent lid should not be open when the cooking buttons are...
Try a hard reset first: Unplug the oven or turn off its breaker for a minute or so, then set the clock & try it again.
If it still fails, did the cooktop lights go out recently?
It may need circuit board repair, which is usually economical.
Oct 27, 2013 | GE XL1800 1100 Watts Microwave Oven
On my GE Profile Microwave the led is lighted and shows the time correctly and displays the led buttons. When I press on the led buttons nothing seems to happen. Also, after some idle time, the led panel...
The touch panel has malfunctioned, Suggest replacing microwave unless you want to attempt repair. If so you will need a replacement touch panel for it.
Jun 14, 2017 | GE Microwave Ovens
Hi I have a new Kenmore microwave model 721.8503 - it is a month old and wont turn on.. I close the door and the light stays on and it wont work..the door is completely shut
It sounds like the light switch isn't being deactivated which is preventing the microwave from operating (a failsafe).
Look to see that the buttons inside the microwave (where the latches are inserted when you close the door) are actually being pressed.
They may be out of place, obstructed, or your latches on the door may be damaged.
If you don't see anything wrong, try pressing the buttons yourself (with a pen bottom) to see if the light goes off.
Dec 18, 2010 | Kenmore Microwave Ovens
Exterior light is not working. The fan turns on, but the lights won't when the button is pressed.
Is the light bulb burnt out? Try replacing the light bulb and see what happens.
Nov 14, 2010 | Whirlpool MH6141XK Microwave Oven
Problem with light,vent, and the boost
Depends on the model #. I dont see it on here. This unit may have some kind of button assy that has broken and fell back into control panel.
Nov 25, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
