Question about Dometic RM2652 Refrigerator
Have a dometic refrigerator( I think RM2652 or RM 2852) in our fifth wheel. I checked the fuses ,the batteries are brand new and checked them. but still no power to the refrigerator. Everything else works in the trailer. Not sure what is the problem.I had the recall done on it a few years back. Seems to be no power to it.
  • Kathy Higgins Jul 11, 2010
    Thank you for your help! We have scheduled the trailer to be taken in to camping world to be fixed. I am hoping that we dont need a new refrigerator. they are expensive. I hope they find a simple reason that the power is not to the frig, maybe a relay switch or something we dont know about. Anyhow thanks for your help.
  • Kathy Higgins Jul 14, 2010
    Just to update you on our refrigerator issue. We talked to Dometic corp. and they said that they gave us our recall fix and that they are not going to do anymore so we have to buy a new unit. Thank you for your help.
  • 11,800 Answers
The recall was about the LPG burner, not related to this problem since you are running it electric. The  electrical system is very simple on these refrigerators - just some wires, a thermostat and a heating resistance, no moving parts. So if the power doesn't comes to the fridge it can be only a break in the power cord  - check that the power reaches the thermostat. If it doesn't then it's in the power cord or the wiring of your RV  . If it does reaches the thermostat but not the resistance (whatever the position ) then it's busted and must be replaced - beware, replacing it will be a pain, access for the tube is very limited.
Posted on Jul 10, 2010
  • Kathy Higgins Jul 10, 2010
    thank you for the information, I have another question? I pulled off a metal panel that shields the tube at the back of the refrigerator. There I found yellow gunk along the bottom and white corosion, something like what you would see on a battery, around certain areas of the tube. I believe the tube is the condensor? It looks like at one time something had leaked but dried up also. Last year our trailer had a very bad rotten egg smell. We couldnt get the refrigerator on last year also. but the book said check the batterys. we did and they were bad so we bought new batteries. This year there is no odor and the batteries are brand new. We never pulled that panel off last year so I dont know how long that gunk was there.
  • Azrael SRL Jul 11, 2010
    That's a totally different problem. Your refrigerator is a condenser type (not a compressor one) and as such it uses ammonia , not freon. Ammonia smells like rotten eggs, if you smelled it it's because you had a leak and that gas in the sealed system slowly leaks out over time; when you looked in the rear of your refrigerator gas assembly and saw a yellow dust, this was the result of the leak. You no longer smell anything now because the gas is long gone.
    The fridge must be taken to a repairman to have the leak fixed and the circuit filled with ammonia.
I have a 1979 dometic fridge in my fifth wheel and it will not work off electric even though it did before, any ideas?
if out let on back of fridge ok then see if 12 ac volts to board check heater element or fuse
Aug 23, 2012 | Dometic RM2652 Refrigerator
RM 2652 will not get cold
Check the 5 amp buss fuse behind the frig.
Apr 04, 2010 | Dometic RM2652 Refrigerator
Dometic 2852 freezer gets cold but refridge does not
If your freezer is getting down close to zero degrees (F) then I doubt that your refrigerant is low. The most common cause of the refrigerator section not getting cool (approximately 40 degrees (f)) is a fan that pulls the coils in the freezer into the refrigerator has failed. A very common failure of a cheep little fan motor. Normally that fan is behind a panel in the freezer section at the bottom. Determine where the cold air in the refrigerator section normally enters and the fan will be above there.
Aug 11, 2009 | Dometic RM2652 Refrigerator
2002 RM 2852, the refrigerator (lower section) will not work its warm inside, but the freezer (upper section) works fine, it will freeze water bottle to hard ice. All fuses are good. Please help!!
cooling unit is bad my friend there is a temporary fix but in my opinion not worth your time take the unit out and flip the refer upside down this sometimes dislodges the blockage in the cooling unit all a rv fridge is is amonia and salt if not used all the time the salt crystalizes in the orfice and blocks the unit a rebult cooling unit 550 about and labor 4 hours at your dealers rate a new fridge about 1500 installed
my shop 360 for labor 550 about for unit 910
I ALLWAYS RECOMEND REPLACING THE FRIDE COMPLETLTY
you get all new electronics and a new box
May 28, 2009 | Dometic RM2852 Refrigerator
Dometic RM2652 Refrigerator Logo
106 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
