Question about Intex Pool & Spa
Intex Deluxe Saltwater System & Filter Pump Model 8111. Have used it about 6 weeks and now the "Chlorine " light does not come on. No codes. Cleaned cells and checked connections to no avail. Nothing on Intex website or manual. Any ideas?
My Krystal clear saltwater filter and pump mod.cs8111
just started making a knocking noise...what do I do,
Posted on Jun 08, 2014
  • Intex Master
  • 8,404 Answers
Do you have 3200 ppm salt in your pool? Have your pool supply place check it for you.
Posted on Jul 24, 2010
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
How do i fix my saltwater pool its green?
it sounds like your chems are off, check you chlorine and PH, I go for a 3.0 to 5.0 on the chlorine side and 7.2 to 7.5 on ph,
Jul 29, 2014 | Intex 2500 GPH Filter Pump Krystal Clear...
In a 52" x 22' Ultraside Intex pool with a saltwater ionizer and a sand pump can I use pool shock to kill algae without damageing the saltwater ionizer system and the sand pump?
There seem to be different versions of algae killer - look for one that specifies that it's safe with saltwater systems (sorry, not familiar specifically with Pool Shock)
Aug 01, 2013 | Intex Automatic Salt Water System for ...
Intex Deluxe Saltwater System & Filter Pump Model 8111. Light comes on, code is 88 but there is no suction, there is hum. I have followed directions on this post for little or no suction, put in new...
I have the same problem! We need a better explained solution. bought from a sale and don't have a manual. I have a new filter in it and full water pressure and just a hum. Only code 88 shows up and pump seems to be getting warm. lease explain solution. you can send solution to wilfam220@yaho.com Thanks, Ken
May 24, 2011 | Intex Automatic Salt Water System for ...
My Krystal Clear Deluxe Saltwater System Model 8110 is not turning on
My pump works, but it wont turn to chlorine, so it then turns the water green, i looked everywhere and cannot find a solution, anyone that can help that would be great.
Apr 23, 2011 | Intex Automatic Salt Water System for ...
Water not clear
cloudy water is mainly due to poor pool maintainence.
Your purchase of the salt water system only helped you with not needing to pour chlorine in or float tablets.
You will still need to use chemecals.
I use a good stabilizer to hold the chlorine level longer
I use a non foaming algecide once a week
I also use a water clarifying product once a week
Now on to the clouds :-)
cloudy water is because of not enough sanitizer mixwd with a crappy pump from intex
I do not know the size of your pool so I will just use mine to show you #'s
I have a 7000gl pool with a 2500gl ph pump
A pool needs to be turned over at LEAST 3 times a day so for me it takes at least 8 hours of filtering alone this does not include making chlorine.
Bottom line is you should run your system 24/7 between generating and straight filtering
The only cure for less filtering is to get a sand filter with at least a 1 horse power pump to pump 4000gl and uphaving a sand filter helps trap more small particles than the cartridge filter.
I noticed the difference the first night I had my sand filter. It ran for 6 hours before me turning my pool light on and to my surprise I did not see as many particles passing my light as with the cartridge filter and the second night nothing Crystal clear.
Bottom line is intex pumps and so on are not big enough for the pool it comes with.
The salt system alone with a sand filter is great
Jun 26, 2010 | Intex Automatic Salt Water System for ...
My water was crystal clear when delivered. I added the salt, ran the filter pump for 24 hrs as instructed. Turned on my Intex saltwater pump and within an hour water is green. Cannot find anything on...
I am not impressed at all with these salt water chlorinators.Shock the water and keep the filter running next day add a powdered chlorine.filter still running. check the balance with test strip in about four hours.If chlorine level is good start vacuming the algee off the bottom of the pool. Now throw away the salt generator and stay with the chlorine packs every week to two weeks continue to monitor with test strips
Jun 17, 2010 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
657 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
