Question about 2wire HomePortal 1000 Router
2wire Home Portal inactive while there is an active signal
Approximately 5 times a day my connection to the internet dies. The 2wire Home Portal icon stops lighting up as it normally does when connected. In addition, my 2wire adapter acknowledges that there is a signal and that the household network is providing a strong signal but it can not connect because it says the Home Portal is down and therefore my computer can not acquire a network address.
How do I prevent this from continually happening? It is a huge interruption to my internet needs.
5 Suggested Answers
  • 7 Answers
SOURCE: I AM RUNNING VISTA CAN I GET UPDATED SOFTWARE FOR MY 2WIRE PORTAL
I UPGRADED TO VISTA AND NOW I CANT GET MY 2WIRE PORTAL SOFTWARE TO INSTALL. IS THERE AN UPGRADE OR NEW SOFTWARE AVAILABLE ? ► there is no need to install the CD if ur trying to connect using an ethernet cable to the 2wire. If ur attempting a wireless connexn, u shud configure the wireless set up.
1000 SW (Model) for 2wire,Connects fine, intermittently the Broadband Link goes ORANGE and keeps me off Internet ► this is a possible line problem. Try plugging ur 2wire's phone cable directly to the phone/wall jack removing the filter or splitter in the process. Then see if the problem reoccurs. If it DOES NOT, replace ur filter with a new one. If it DOES reoccur or if it is already connected to the phone/wall jack directly, contact ur Internet service provider.
keep me posted on these...
Posted on Jan 27, 2009
Selvol
  • 115 Answers
SOURCE: connect panasonic bl-ca10 cam to a 2wire home portal 1800g
Try using WEP instead of The WAP protocol.
It worked for me.............
Posted on May 19, 2009
ciscoroute
  • 87 Answers
SOURCE: 2wire portal router, after year of wireless connect, stopped
it could be that the wireless part of the unit has failed but to test, can you make sure and try while sitting very close? Also, check for any new appliances close by causing interference
Posted on Jul 08, 2009
  • 20 Answers
SOURCE: I recently upgraded from my 2wire DSL to Uverse.
That means the older 2wire card was a B model adapter, which can only run at 11mbps. The other laptop most likely has built in wireless or some other adapter in it that runs on the G model, which is 54 mbps. There is no way to fix this issue, other then aquiring a new wireless adapter for your older laptop.
Posted on Jul 12, 2009
2Wire Home Portal 1100 for AT&T DSL connection problem
HI! read your posting regarding the situation that your experiencing.. If before you dont have any problem regrding your connection with out the cisco network magic. I suggest that before you install the cisco network magic. you should get the full version not the trial version, there is a limitation of setting up the trial version.. Cisco network magic is a plug and play and easy to setup if you get the full version. I dont see any problem regarding your connection with the 2wire and the linksys router, becoz you mention earlier that hime network is working and you can connect to the network and the internet..
Jul 24, 2009 | 2wire Computers & Internet
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Dec 15, 2008 | 2wire (1000-400108-001) Router
Cannot get 2wire to work on my iphone! :(
Try this one:
>on ur WIFI networks, click "other..."
>then manually type in ur network name (if its set to default, it should be 2WIRE and the last 3 digits of ur SN. It is case sensitive so type the name exactly how it looks like.)
>make sure that the setting is set to WEP
>on the password box, enter a dollar sign/$ first and then the 10 digit code under ur 2wire
keep me posted on this one
Aug 30, 2008 | 2wire (1000-400106-003)
Connect panasonic bl-ca10 cam to a 2wire home portal 1800g
Jul 06, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Hg1000 home portal
do you mean the modem's ip address?
http://gateway.2wire.net
http://homeportal
http://homeportal/setup
http://192.168.1.254 (software version 3.7.x and higher)
http://172.16.0.1 (software version 3.5.x or earlier)
hope this is the one you're looking for...?
Apr 06, 2008 | 2wire HomePortal 1000HG DSL Modem and...
Home portal not yet activated
XP is an very good OS which will connect with 2wire without any problem.
If your computer is not able to detect modem, pls follow these steps.
* Check for damage of ethernet cable
* Try to reset the modem by using a paper clip punching into the reset button
* Even if your modem is not detected, force the IP and Default gateway
Take care
Feb 26, 2008 | 2wire HomePortal 100W (1000-400026-000)...
Unable to access homeportal, but internet is ok?! (2wire 1800hw)
I had the same problem. I reset the home portal to factory setting and uninstalled the 2wire software from my main computer. I then reinstalled the system using installation cd that came with 2wire.
Jan 21, 2008 | 2wire HomePortal® 1800HW Router...
No internet connection using wireless
i strongly recommend if you try calling your isp provider again, i blv they actually have specialist trained for 2wire connection, you just have to ask for them...vista still has compatibility issues, did your router worked wireless with other pc like xp?..i hope you'll have this resolved already...
Nov 27, 2007 | 2wire 2700HG-B Router (2700HGB)
Can't connect one laptop
Ok this is a simple, but difficult fix at times. I need to know if the other laptop is used in and or outside of your home? In addition I need to know if you have security like a WEP or WPA setup? Do you have a home network setup using this router/modem? I may have other questions, but these I need to know in order to give you an exact answer!
Nov 25, 2007 | 2wire (1000-400108-001) Router
Open Questions:
2wire HomePortal 1000 Router Logo
121 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
