Question about Fedders A6K32E7B K Chassis Room Air Conditioner w/ 32,000 Cooling BTUs & Electronic Controls
Have anair conditioner that cycles on and off
Have a fedders 32k btu air conditioner that cools for 3 minutes and stops cooling for 10 minutes (continuous cycle). Have replaced control panel and capacitor. all other outside parts appear to be working. What else can be tested?
  • j1delvalle Jul 10, 2010
    have a fedders 32k btu air conditioner that cools for 3 minutes and stops cooling for 10 minutes (continuous cycle). Have replaced control panel and capacitor. all other outside parts appear to be working. What else can be tested?
  • 532 Answers
If your A/C stop cooling check the follwing.
Check your filter. This is paramount as a dirty air filter will restrict air flow and limit the efficiency of the condenser to cool the air. Typically it is recommended that the air filter be changed every month but there are some on the market today that require three month replacement.
Make sure the exhaust vents in all the rooms are open and free from debris. If your duct system is in the ceiling make sure they are fully open. If the system exhausts through the floor make sure they are fully open and not covered by shoes, clothing, furniture and/or household items.
The outside unit should be free of any obstructions or debris as this will reduce the amount of air passing through the condenser.
Thanks for contacting Fixya.
Posted on Jul 10, 2010
    could the unit be needing coolant?
  • 10,865 Answers
Hello. Replace the thermostat to solve the 3 minutes on and 10 minutes off issue. J.
    The thermostat is part of the recently installed electronic control panel.
    Does the thermostat connects directly to the capacitor or some relay?
Whats the right settings for the window air conditioner.
i operate my a/c's in summer at 72 to 74 degrees. in the winter at72 to76.
Jul 30, 2015 | Fedders AED24E7F Wall/Window Air...
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
Air conditioner not cycling
if its running all the time and cooling not enough btu's for space
Aug 06, 2014 | Fedders X Chassis A6X08F2A Air Conditioner
I have a Fedders A6X08F2A-B Service # and Serial # MP 178550 and I would like to have the specs on it eg: how many BTU's, model # etc
Hi, The numbers you have given tell me, this unit is a 8,000 btu unit.!2, 000 btu's equal a ton of cooling, so you are just under a ton. This is about all I can tell you. There should be a data plate that will give you amps, volts, compressor amps ect.
Shastalaker7
A/C, Contractor
Jun 10, 2011 | Fedders X Chassis A6X08F2A Air Conditioner
How many BTU's does model AEJ12E7AG have?
Ronnie,
You have 12000 BTU/Hr Cooling and 10000 BTU/Hr Heating
Tim
May 29, 2011 | Fedders AEJ12E7AG Air Conditioner
Purchased a fedders a/c 18000 unit still under warranty. called the 800# they said company had filed bankruptcy and were not responsible for repairs. 350$ mistake. Fan runs too slow for unit to kick in....
Check the capacitor for the fan motor. You can do that with a multimeter with the capacitor test function or if the capacitor looks swollen then it is probably bad. Also, make sure the fan rotates freely by hand. Let me know if you need more help.
Jun 08, 2010 | Fedders 12,000/10,200 BTU Heat/Cool Room...
Can't find a manual for air conditioner
BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
To convert
Multiply by
To obtain
kW
1.341
hp
kW
3,413
Btu/hr
hp
2,545
Btu/hr
May 21, 2010 | Fedders Q Chassis A6Q10F2A Air Conditioner
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Fedders A6K32E7B K Chassis Room Air Conditioner w/ 32,000 Cooling BTUs & Electronic Controls Logo
Top Fedders Heating & Cooling Experts
Donni Steen
Sheldon Dedek
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
