Question about Lexmark Office Equipment & Supplies
Paper isn't feeding properly - goes halfway, but doesn't print anything - and then stops. What do I do?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with then clean the print head and the area where it feeds the paper. To clean the print head take a hot water towel with the printer unplugged and the cartridges out, clean it till the time you see there is no ink residue on the towel. If still the issue is not resolved then it seems that the feeding unit should be checked along with the sensor. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
HP deskjet 3845 will not feed paper to print. Is the green light suppose to blink? Not sure where paper needs to go to get proper feed
Paper goes in the bottom tray. Take a small stack and place it in the bottom tray and push it in until it stops. It will feed out of this tray, print it and output it to the top tray.
Jul 12, 2010 | HP Deskjet 3845 InkJet Printer
HP C4100 Series Printer - Paper Feed & Print
The feed rollers might have to be cleaned or it could be a logic problem (main board) issue.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Jul 31, 2009 | HP Office Equipment & Supplies
Paper feeding halfway through then stops
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Samsung CLP 300 Laser Printer
Rogue jam
When on printer print test page always
Apr 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper Jam
If it truly stops halfway then it must be obstructed by seomthing. If it only gets a short way past the pick up roller then it may be something else. A little trick for removing obstructions is to fold your paper in half or even a quarter so it is much thicker and stronger and try to feed that through. This can push through any obstructions (assuming they aren't too big). If it still gets stuck see if you can manually turn the main gear found to the side of the carriage and try to push the paper through that way (hence pushing through your obstruction). If your paper feeds through fine doing this then you may have another issue.
Good Luck.
Please rate my advice, good or bad.
Feb 03, 2008 | Lexmark All-In-One Printer
Printer jam
open top cover of your printer and put a couple of drops of 3 in 1 oil on the carrige bar ( THE BIG SILVER BAR THE INK CARTRIDGES RIDE ON)
THEN CLEAN ALL THE RUBBER FEED ROLLERS WITH A MICROFIBER TOWEL MOISTENED WITH ISOPROPANOL ALCOHOL THEN TRY THE PRINTER AGAIN
Jan 11, 2008 | HP PSC 1315 All-In-One InkJet Printer
Feeder
Paper being printed or Sent? but prob Dirty feed roller (paper feed or doc feed roller)
Oct 11, 2007 | Brother MFC-8220 Fax
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
