Question about Homelite Garden
What are the carberator settings for a homelite bandit sx-135 weed eater?
    President:
  • Homelite Master
  • 1,545 Answers
If it's a Zama 2-stroke carb...the reference settings for the high and low speed needle jets are... turn them all the way in till they are snug and them bring them back out about 1 1/2 turns. (one and a half ) That is a good starting point for their carbs and should get it to start so fine tuning can be done.
Posted on Jul 10, 2010
I have a SX-135 weed eater. I am not getting a constant spark when I pull the starter cord. It does not have an on switch just a kill button. The spark plug is new and the gap is set at 0.025. I rebuilt...
If you are not getting any spark, it's the ignition module
runs about 65 dollars. may be cheaper if you shop around.
if you have access to an ohm meter , set it above 12vdc
common to ground, and the positive in the spark plug
boot, sometimes the connection can break from connecting
and disconnecting, pull on the cord as if to start it, if the
ohm meter shows 12vlts or above, the ignition module
is good, if it shows less than 12vlts the ignition module is bad. good luck!
Jul 09, 2011 | Homelite Garden
Restringing a homelite bandit trimmer
What is the correct size of the nylon cutting material - on my homelite bandit SX-135 trimmer ?
Thanks, Bill.
Apr 30, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
My homelite weed eater sx-135 the fuel filter broke of the tube
The longest, and sometimes smaller in diameter, fuel line goes from the carb. to the bottom of the tank. It should rest comfortably on the bottom of the tank. The other line should go from the primer bulb to just inside the gas tank, (about an inch).
HINT: Cut the fuel lines at an angle before inserting them into the gas tank. This will allow you to get them in much easier.
If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
The longer, and sometimes smaller in diameter fuel line, goes from the carburetor to the bottom of the tank. This line, which has the filter attached to the end, should rest comfortably on the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch, with that very small piece of plastic attached to it. This piece of plastic keeps this line from pulling out of the gas tank. this line serves as an overflow from carb.
Jim
Need manual for homelite sx-135 weedeater
http://www.homelite.com/service_support/order_parts
Feb 14, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Garden Logo
710 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
