Question about Amana NED7200TW Electric Dryer
Drayer runs but does not heat up what's up - Amana NED7200TW Electric Dryer
  • Amana Master
  • 43,501 Answers
Hi, If you have a gas dryerdrayer runs but does not heat up - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out thidrayer runs but does not heat up - 2_bing.gif I wrote about this problem...
Dryer Troubleshoodrayer runs but does not heat up - 2_bing.gifrc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jul 11, 2010
2 Suggested Answers
yalmer
  • 549 Answers
SOURCE: drayer working but no heat
No heat may mean that one side of the 240 volt circuit breaker is tripped or one fuse of the 240v circuit at the fuse/breaker box is tripped. Just replace/reset the fuse or breaker which ever you have.
Dryers will have controls working but not heat if it happens to be that particular side of the 240v circuit that tripped or fuse burned.
Posted on Feb 06, 2008
Service center in dubai
You didn't mention if it was gas or electric, model number, etc.
Apr 18, 2014 | AEG Dryers
Drayer maytag ld69304aae
Possible that the heating coil had failed, the connection to the coil has failed or the control panel is not outputting the voltage to the coil and is a suspect. You need to use a tester to check the coil and line continuity before the board could be suspected.
Jun 03, 2013 | Washing Machines
Drayer stops after a couple of min
You mean the Heat or the Motor turning the Drum?
Jan 17, 2013 | Whirlpool Dryers
My drayer spins and spins but does not get hot, is not drying. Why?
most likely a faulty heat element or thermal link on the heat element canister. check with ohm meter. replace.
Jan 30, 2010 | Kenmore Elite 45986 Front Load Washer
My drayer heats up very slowly since one week .what could be the problem
sounds like it could be more than 1 problem 1 the heating element could be shorted and only running on a partial element 2 you could have a blocked exhaust vent and its not allowing the hot air to circulate properly
Jan 07, 2010 | Whirlpool Dryers
Tumble dryer not giving heat
is the drum turning?if the drum is ok sounds like the thermo fuse on the heater box failed,most of the time it's from a clogged dryer vent hose or wall vent,let me know what you find-mike
Nov 13, 2008 | Dryers
L G DRAYER , HEATER NOT WORKING
Had the same problem on a whirpool drayer. Get our multimeter and check which heat fuse is broken. Take that one out and throw it in the floor until you have conductivity again. Clean drayer vents and heater. This worked for me, good luck. http://www.youtube.com/watch?v=UuFQOuSlzlw
Nov 03, 2008 | LG DLE2532W Electric Dryer
Tumble dryer
Can be a few things. Start by resetting your circuit breaker. The dryer motor can run with partial power but the heating element cannot. Make sure your not set to a no heat setting. After those checks you have to get into the mchine to check your heating element and thermostats.
Apr 12, 2008 | Whirlpool LER5636P Electric Dryer
Drayer working but no heat
Jan 30, 2008 | Dryers
Draye heat work but not dry
check your exhaust vent hose inside and outside your hose you should have alot of air coming from the dryer to outside this is where Id start
Dec 30, 2007 | Maytag HYG2460AWW Gas Dryer
Amana NED7200TW Electric Dryer Logo
194 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
