Question about Kirby Ultimate G Bagged Upright Vacuum
How do I get the belt back on the power brush?
Kirby Ultimate G - How do I get the belt back on the power brush?
  • 10,319 Answers
THE SQUARE FRONT PART ON THE HOUSING TURNS TO OPEN TO SEE THE BELT. tHAT IS WERE YOU WILL PUSH THE BELT BACK ON
Posted on Jul 10, 2010
Kirby g4 brush wont turn belt ok
your belt has probably been stretched to the point where it will not work so good.
Jul 02, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I need to replace the belt on my kirby.
If this is like my Kirby, there are colored slots on each end that slides the brush in and out and they are different sizes but the belt is connected in the middle. First take the bottom cover off. It should be made out of rubber and metal, and it pops off, you then slide out the brush, take the old belt off and look up inside where you took it off and there is s hook so you first hook the belt on there and stretch it and slide the brush back thru it and then stretch it a little so as to slide it back into the slots on each sde when it is in place you then put the cover back on and your done.
May 18, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I have no idea how to put the belt back on
Take the nozzle of, remove the brush roll, put the a new belt over the brush roll, re-install and put the bottom plate on, making sure that the belt is in the middle of the brush roll. Turn the big knob on the front until it locks, when it grabs the belt it will be hard to turn. Re-install the nozzle on the machine and lock it down. Turn the knob again all of the way, this will release the belt unto the pulley.
Jul 13, 2008 | Kirby Ultimate G Bagged Upright Vacuum
How to change a band on a kirby vacuum?
I think you mean belt??
Jul 04, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Hi....Need Help please....
Put the belt on the brush roll, place it in the nozzle, make sure the belt is in the center, turn the big knob on the front until it locks, then install the nozzle on the vac., turn the knob in the other direction, and it will be put on the pulley.
May 11, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G will not suck with main brush head attachment
You may need a new belt, it may have stretched enough so it isn't turning the brush roll anymore.
Mar 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Replacing Belt
On the front of the power head is a knob with the KIRBY name on it. Rotate this knob in a counter clockwise direction and it will "lift" the belt off the motor spindle. Release the head lever, only one direction it will turn and remove the head. Turn the head over on its back, turn the KIRBY knob to release the old belt. Remove the brush guard by turning the two release fixtures. Remove the guard. Pry the brush out of the head. Remove the old belt. While the brush is out remove any build up of hair and lint off the ends that's where the bearings are. put a few drops of 3 in One oil on the ends. Put the new belt over the brush and re-install the brush into the head. the brush will go in only one way. With your finger pull the belt into the housing and rotate the KIRBY knob until the pawl inside grabs the belt. Re-install the brush guard by engaging the two metal pieces into the front of the head and pull down backwards over the head and rotate the holding clips back horizontal. re-install the powerhead on the machine, lock it in place and rotate the KIRBY knob clockwise. You should be all set!
Aug 23, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate won't clean carpet
when you install the hose connector it trips a switch that switches the vac motor into high speed because the vac path is longer using the hose. check the belt after you remove the front. make sure the direction of rotation is in the direction of belt travel stamped in the impeller. try adjusting the head height
Aug 13, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
81 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
