Question about Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0
My trekstor hard drive was fine and we haven't plugged it into the computer in a while and now the light is flashing red to blue and the computer won't recognize it.
The cheapest solution,believe me is to take of the hd from the case and put it in your desktop.there is no need going to bios if tou have one hd in your pc.it ll trace it automatically.i had the same blink blue red problem and now works just fine.the only disadvantage ia that you are not portable after that.try it.it works.
Panos,Greece.
Posted on Mar 24, 2012
  • 11,800 Answers
The hard disk inside your external unit has died. If you want to keep the case it can be replaced with a standard SATA disk.
Posted on Jul 10, 2010
3 Suggested Answers
computus
  • 487 Answers
SOURCE: Just need to ask, trekstor external HD light is
Hi, unfortunately your are probably right. You can buy a new hard drive and install your self as the cheepest option?
  • 10406 Answers
SOURCE: trekstor hard drive, connected to power source,
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Posted on Nov 18, 2010
Red and blue light keeps flashing come up with unknown device
is this an external usb drive or just a usb drive??
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Sep 23, 2011 | Trekstor Computers & Internet
Nothing happends when i plug in my trekstor with usb..model nr is mspcuc.ess-a
if your computer came with a motherboard disc the drivers could be on it
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
May 02, 2011 | Trekstor (21329) 250 GB USB Hard Drive
Its is blingking red ang blue and say driver not recogniced
hope this helps
Apr 10, 2011 | Trekstor DataStation maxi m.u SATA 3.5"...
My 750GB TrekStor external HDD failed. The light at the front of the device went from BLUE to RED and the machine seems to start to boot up the clicks a few times and then nothing. I cannot view the...
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 25, 2010 | Trekstor Datastation maxi t.u SATA 500 GB...
Jul 10, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Constant blue flashing light,computer will not detect
I dropped my Trekstor 500GB hard drive and now it registers as a removable disk with message "please insert disk into removable disk". My computer is a Windows vista. Can the Trekstor be repaired and can I retrieve my data. Until now it worked perfectly. Paul
Feb 12, 2010 | Computers & Internet
Trekstor 160g hard drive, disconnected whilst in
your hard drives logic card has bursted
so contact to your's hard drive recovery console
Aug 27, 2009 | Trekstor (21202) 160 GB USB 2.0 Hard Drive
DataStation Maxi M.U. 500 Gb blinks red and blue, doesn't read
I just had this problem with both my external drives (I was using the same power cable and just alternating between them). I went and got drive B's power cable and they work fine now. Try replacing the power cable
Jul 19, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Not loading
You will need some kind of disc utility.
Open the utility with the drive connected and it should show up in the options of drives.
You should then be able to format the drive.
It should then be usable.
If not take it back to the shop..
Dec 16, 2008 | Trekstor DataStation maxi m.u SATA 3.5"...
TrekStor 160gb Harddrive wont turn on
Try to turn it off and quickly turn it on again in a split second.
And buy a second hard disk just in case.
Sep 28, 2008 | Trekstor (21202) 160 GB USB 2.0 Hard Drive
Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0 Logo
1,517 people viewed this question
Top Trekstor Computers & Internet Experts
Marcin
vojvodabudva
ray gallant
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
