Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL
I lost the manual of my Maytag Neptune TL could you tell me what the Lr stands for?
  • 3 more comments
  • Anonymous Jul 12, 2008
    Machine stops and has an unreadable message. Have to restart it and manually put it to spin. Lost my manual. Is there a chance that I could find another one? Regards, June
    How do I go about replacing the manual I lost? Regards, June
  • Anonymous Mar 12, 2014
    how can you tell if the pump is bad on a maytag neptune
  • Anonymous Mar 18, 2014
    MAYTAG NEPTUNE TL KEEPS SAYING ERROR BETWEEN CYCLES
  • Anonymous Mar 22, 2014
    None
    Scholar:
  • 79 Answers
See the new Neptune Help Song at www.neptunehelpsong.com. It reminds folks to replace their faulty door latch wax motor which was shipped with the MAh3000, MAH4000, MAH5500A and the 2000 stackers.
Posted on Feb 08, 2009
Lr stands for motor not running properly.  Solution says to call for service.
Posted on May 12, 2008
    President:
  • Maytag Master
  • 2,651 Answers
Heres a complete sevice manual for your unit tells all about it http://www.servicematters.com/maytag_library/docs/16022808.pdf
Posted on Apr 23, 2008
Yes I just want to know I it's worth fixing this prob. I have a maytag Neptune tl washer model fav6800aww it's starts fine but after 3 minutes it stops on wash cycle an after 5 minutes Lr shows on...
Lr error code is locked rotor. Could be a couple different issues.
Google this phrase and read thru the post ""[FIXED] Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin""
Post in that forum if you want to DIY I do not offer DIY help here any more.
Jul 12, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl error op
You have lost signaling thru the Left Hand Lid lock or you could have a Lid Magnet out of posistion;
Google Neptune TL Washer FAV6800AWW
6 or so post down and I have service notes to help you troubleshoot.
Mar 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl what is code Lr
LR is the error code for Locked Rotor.
This could be an issue with the Motor Controller or Control Board.
I have not seen Drive Motor cause this issue to date.
If you want to investigate further I would suggest getting the FAV6800A/FAV9800A Service Manual.
Google this ""Neptune TL Washer FAV6800AWW""
This is a sticky for the FAV6800A/FAV9800A washer DIY support. Go to the 5th post down in the Sticky and you will find a link for the Service Manual.
If you want to go further in troubleshooting and possibly a DIY fix just open a new thread in that DIY forum with Model number and Serial number. That info is found tag behind the console right back side as you face the machine console.
Feb 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
0. We need a manual for Maytag Neptune TL. IT IS
f your machine is a FAV6800A or FAV9800A see if this post will help. Service manual link or located there. here it is just in case
Clutch Fix
Here it is just in case;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Jun 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Code LR keeps coming up on my Maytag Neptune TL every time it starts to rinse and I have to stop the washer, wait for it to unlock and start it over again.
can't find lr code open it up inside there is a tech sheet stuck to the side inside the washer put it back when u r done so it will allways be there
Dec 25, 2009 | Washing Machines
What does error code Lr mean and how do I fix it?
http://www.bobvila.com/wwwboard/messages/155863.html
says:
just an FYI to anyone who might need to know. my neptune started kicking up an error of LR and stopping. i ended up sending an email to maytag and got a response back from one of their techs. the LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit board at the top of the unit has lost connection to the motor and its control board at the bottom (connector loose) or 2) the motor and or control board at the bottom have trashed and need to be replaced (P/N 12002039).
hope the info helps someone as i had a heck of a time finding it.
Dec 21, 2008 | Maytag Neptune Washer
My neptune TL displays the code LR.
LR usually means that the the signal from the board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first.
Dec 13, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL FAV6800AWW dual turning disks
The center hub on each will unscrew, once you remove this the rotor will come out fairly easy.
Nov 23, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Fills with water but wont wash or spin
The code LR stands for locked rotor you will need a new motor and motor control kit pretty expensive and only covered under you warrenty for a year!
Aug 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Lr code
sometime resistor are a bit under valued and can burn up. Dont worry about your door lock. remember Lr stands for locked rotor.????? check the winding on your motor and never over look the pump. Have a visual inside the pump for blockage look for any shorts on your washing machine. I was told they have a ten year warranty on the motor. I always test all the conponents on a w/machine before I test it. lookup this site to see if your maytag is still under warranty???? maytag.com
Aug 15, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
707 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
