Question about Dewalt Garden
Pressure washer won't pick-up soap
DP 3750 runs fine. Won't pick up soap. Using black (soap) tip.
4 Suggested Answers
  • 2841 Answers
SOURCE: Soap won't siphen on a Honda 160 and I'm
Most of the time this is caused by a clogged inlet valve on the soap dispenser. You need to disconnect the hose from the valve on the pump, then remove the valve and clean it. Be careful as there is a tiny spring and tiny ball bearing in the valve. Notice which way it goes together when you dissemble it so you will put it back together correctly. Clean the spring and ball bearing throughly. Clean out the valve and remove any soap residue. In the future make sure to flush the valve throughly with clean water for at least 2 minutes before shutting the unit down. Also check the filter on the hose your stick into the soap to make sure it is clear.
Posted on Jul 03, 2011
jj505
  • 195 Answers
SOURCE: pressure washer won`t pressure up
Have you tried adding 30 wheight pump oil,under 1 qrt usually
Posted on Mar 19, 2009
  • 259 Answers
SOURCE: Pressure Washer Troy Bilt 2700
Take the small soap line off and make sure you can blow air through. Where the line attaches to the soap container make sure the hole is clear if not take a streight pin and make sure the pin goes in the hole easily.
Posted on Mar 14, 2011
How do you use additive hose with pressure washer
In order to get the system to pick up whatever solution you have the pickup tube in, you have to use the black, soap tip on the spray wand. If you use any of the high pressure tips, usually red, yellow, white or green, there will be too much pressure in the line for the siphon system to work properly. There is no way to control how fast the system picks up the cleaning solution, so if it's using your solution too fast, dilute it with water in a five-gallon bucket so it doesn't go through your product so fast. After you use the soap tip to soak down whatever you're cleaning, switch to the appropriate pressure tip and rinse everything down.
Jul 04, 2012 | Campbell Hausfeld Garden
Craftsman pressure washer how to adjust soap 2300 psi
A common mistake made when using the soap pickup function on pressure washers is to use one of the high pressure tips, usually green, white, yellow or red. If you are using one of these there will be too much back pressure in the line for the soap dispenser to work. You have to use the low pressure, soap tip, usually black, for this function to work.
Jun 28, 2012 | Garden
Pressure washer will not apply soap
pressure washers will only pull soap when using the large opening black tip or no tip at all they will not apply soap under pressure
Jun 23, 2012 | Garden
Wash solution won't dispense
it will only pull out of the sulution when there is no tip or when using the tip that has a large hole i think its the black one
May 18, 2012 | Garden
The cleaning solution is not spraying out of my pressure washer.
On pressure washers with cleaning solution pick-up hoses you have to make sure you are using the black, low pressure, soap tip. If you are using the high pressure tips, red, yellow, white or green, there will be too much back pressure at the pick-up tube for it to work properly. If you are using the soap tip, check that the pick-up tube and filter are clean.
Jul 06, 2011 | Karcher Garden
It will not **** in cleaner soap
Your heading is for chain saws but going by your problem I'll assume you are having problems with your pressure washer. The most likely reason your washer won't draw the soap into the water stream is you are using one of the high pressure tips, usually red, white or yellow. The only way the soap system will work is if you use the low pressure, soap tip which is black. Another thing to check is the soap line and pickup filter to make sure they are clear and allow the solution to be picked up.
Apr 14, 2011 | Garden
Pressure Washer Troy Bilt 2700 PSI 2.3 GPM will not pick up soap. I am using the black tip low pressure head and it still does not pick up the detergent. Any recommendations?
Mar 14, 2011 | Garden
John deere 3800psi pressure washer will not siphon detergent. the water end does fine but cannot get any soap
The only way the washer will draw soap into the line is with either the black tip installed or with no tip in wand at all.There is a ball and spring inside of the pipe that the siphon hose hooks to so when you use the washer with alot or even a little pressure the ball is forced up and blockes off the soap inlet port.So if you use it with no tip in the inlet port is open cause the ball isnt being forced up by back pressure.I hope this makes sense.
May 18, 2010 | Dewalt 3800 PSI Pressure Washer
Troy bilt pressure washer 2200 psi
inlet valve connected to water inlet is stopped-up. Unscrew it, take a safety pin run through valve then take the pin and push through valve connected to pump. should do the trick. (the valve the suction hose for the soap is connect to)
Mar 31, 2008 | Washing Machines
Garden Logo
525 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
