When I turn on my Carrier V the fan runs but when the compressor tries to start the unit shuts down
    President:
  • 4,070 Answers
Hi! Does it happen most often? Timer settings setted? Hope to know more. THanks!
Posted on Jul 10, 2010
  • dougbras Jul 10, 2010
    Thanks for the reply was kicking out last weekend worked fine all week . the custumer shut it off last night went to stat it this am and it will not start the compressor
  • dj_relly999
    dj_relly999 Jul 10, 2010
    But once turned on after shut down it will work again? Then shuts down when compressor kicks? Am I right?
Air condition motor not going on
check to see if the fan is running if not it has frozen up over the winter. turn off fuses to a/c unit then try to turn fan by hand,if not soak down fan bearings with penetrating oil like PB Blaster keepmoving fan blade back and forth until it spins freely. Then try turning on the power to a/c unit if motor then turns fan freely , shut it down again and use a good coat of a-1 motor oil (ELECTRICAL) on the fan brgs. This should get you through for another year or so. On the other hand if fan will not spin by the motor now but spins by hand then the fan motor is bad.
Apr 14, 2013 | Carrier Payne 2.5 Ton Air Conditioner...
Window unit (110) cools for a few minutes then stops cooling just fan air unit is about 6 0r 7 years old
It sounds like your compresssor is shutting off on an overload. After the overload cools down the compressor comes back on until the overload heats up and shuts the compressor off again.The fan keeps running as it is not on the same circuit as your compressor.
Aug 02, 2011 | Carrier YC273D Air Conditioner Window/Wall
Carrier outside unit not starting and is very hot
Either the condenser fan is not working and it has shut down on high pressure... or the compressor is locked up and trying to run and is making the heat...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 13, 2010 | Carrier 38CKC036 Air Conditioner
Possible Contactor Issue
Sounds like a bad fan switch in your unit. That unit has a fan board in it that is time delay on and off. Turn the fan to the on position and let it run all the time. If it keeps temp and does not shut off it is the fan realy board. The board also controls the compressor. Check that first and then the tsat. Russ
Jul 24, 2009 | Carrier 38CKC042 Air Conditioner
When unit starts the condensor fan only comes, not compressor
You need a new fan motor and the correct capacitors for your sydtem I think they are 35 or 45 5 cap. Try a hard start kit on compressor. Are you sure you have the cap wired correctly?Russ
Jul 16, 2009 | Carrier 38CKC036 Air Conditioner
A/C Problems
SOUNDS LIKE THERMOSTAT IS NOT SET UP CORRECTLY THE HAVE TO BE PROGRAMED TO YOU UNIT
Aug 28, 2008 | Honeywell Electronic Programmable...
Compressor shuts down when warm outside
make sure you provide shade for your unit. It may help keeping it cool.
Aug 27, 2008 | Honeywell Electronic Programmable...
Compressor not doing much
I am assuming that you are talking about a central ac unit. On a central air unit the outside fan must be running whenever the compressor is. If it's not the compressor will shut off from overheating withing minutes. First you need to shut off the unit for several hours and let it cool completely down. Then turn it on briefly to see if the compressor starts and see if the fan tries to start.( I am assuming the compressor starts and runs.) If the fan won't start try testing the capacitors. There are usually two one for the fan one for the compressor. Sometimes there will be one combo one. Mark the wires and remove the capacitor. Get it tested and if bad replace it. This will probably do the job. If not test for current at the fan motor. Also test to see if it turns freely. The motor may need to be replaced. This will run about $50. The capacitor should always be replaced when the motor is changed anyway.
Jul 09, 2008 | Carrier 38BRC060 Air Conditioner
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
