Question about EdgeStar AP14000HS Portable Air Conditioner
The bottom plastic panel of my EdgeStar AP 14000 HS is cracked and leaks water. It is still under parts warranty so I expect a free replacement panel to be provided by EdgeStar. Question: how do I install this panel? Will the old one lift off after I take the bottom casters off?
  • 3 more comments
  • Gene Lawson Feb 10, 2011
    A while back EdgeStar did send me a replacement pan. I'm still not happy cuz i suspect the original was cracked on arrival, I just didn't think to inspect it. Anyhow, two weeks ago I decided to do the swap-out. I took the screws off of the back panel and rotated it up and when I looked at what laid ahead, I put the panel back on and started thinking about Plan B. Your detailed description is very helpful/instructive. Even though I actually enjoy repairing things and am fairly handy with tools, I don't think I am going to attempt the replacement. Instead I am going to use an epoxy glue for plastics and hope that works. And maybe some vehicle radiator hose repair tape. I will definitely save your instructions. Thank you very much. Gene, Redmond, WA.
  • Gene Lawson Jul 02, 2013
    by any chance, do live in the Seattle, WA area? If so, I'd like to "hire" you to assist me in my pan replacement.
  • Gene Lawson Jul 05, 2013
    When the pan cracked further disabling one of the casters/rollers, I decided I had nothing to lose by trying to replace the pan myself. I followed "ErniePower"'s suggestions and after a few hours I was able to complete the task. I did mark anything/everything I could before lifting the unit off of the pan cuz I knew it would be difficult remembering where everything went when it came time to reassemble. Labeled screws so I knew which ones went where; couple different sizes. I took a lot of pictures. suggestions to those contemplating a similar replacement: to work on the unit, put it on a platform at least waist high with plenty of space surrounding the unit. I used an old door slab with sawhorses for support. Take the rollers off first; will keep the unit from moving while you are working on it. You do need another person to help with lifting the unit off of the pan and then putting it back on the new pan; very bulky and somewhat heavy. After you are done, DON'T turn it "on" rightaway especially if the unit was on its side during the repair process. Let it sit for a day or two to let the oil in the compressor settle back down to where it belongs (at least that is what I read). I still have some pictures of the unit after the housing was removed if anyone wants to view them. Good luck !
    Picture of EdgeStar AP 14,000 HS with back cover off
I just replaced this pan on my unit. I have to admit it was more of an issue than I predicted. You need to remove the screws from the back cover of the unit. Then you can swing the back cover up like a hinge until it is sitting upside down on top of the front cover. Be careful not to damage the wires connecting to the circuit board. You can then remove the circuit board. After the circuit board is removed, you can remove the screws and the front cover. (note, you will have to spread the front cover to get the tabs on the center mounting locations to pop over the frame. After the front cover is removed you will see several things mounted to the base. I removed all of the fastners including the large nuts holding the compressor down. Then with some help,from a second person I lifted the unit and pulled the base away. I had to remove the yellow ground wires from the compressor in order to remove main unit. you will notice now that there are a few pieces attached to the base. I removed each piece and reinstalled it on the new base. then I assembled the entire unit in reverse.
Posted on Feb 09, 2011
Why is our dishwasher leaking water
There are 4 places it could be leaking. 1) at the connection where the water line connects to the dishwasher. If the dishwasher has been in operation for a long time then this is not likely to be the problem. If this were the problem you would notice water even when the dishwasher was not running. 2) at the drain hose connection. You would notice the water during and shortly after a drain cycle. The drain outlet is usually a hard plastic over which the rubber drain tube is clamped. Either the plastic could crack or the hose could dry out and crack. 3) The seal around the pump could be leaking. 4) The door seal could be leaking, though this in not usually the problem. You can probably determine the problem by removing the bottom panel so that you can see underneath the unit, and then run a cycle. There are usually 2 screws between the door bottom and the lower panel (near the sides of the machine) and 2 more screws at the
bottom of the lower panel (the recessed part of the panel) near the sides. Don't stick your hand under there because you will have power to the unit and a wet floor. That is a bad combination which could be lethal. Just shine a flashlight under and see where the water is leaking from as it runs. Remove power at the circuit breaker before trying to do any service on the unit.
Aug 22, 2014 | KitchenAid Dishwashers
Washing machine
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Aug 04, 2008 | GE WJSR2070B Top Load Washer
Aprillaire 760 leaks from the bottom left of the case. panel is new, drain is clear, all vents open in the house, the panel cage is free from excessive scale. Any ideas?
Here is a link to your humidifier http://www.iaqsource.com/article.php/my-aprilaire-humidifier-is-leaking-what-to-do-about-it./?id=35
Oct 19, 2011 | Aprilaire 700 Humidifier
Cant stop the timer leaking
Open following link for some Gardena resources, including manual and link to gardena site.
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
Gardena certainly has a glossy site, but I have been unsuccessful trying to contact the company.
Their products come with warranty and they show parts, but no hint where you can buy parts.
I do not know how to fix your plastic timer valve, or if parts would actually repair the thing.
Maybe glue except I don't know a plastic glue that holds on outside of device under water pressure.
Plus I cannot see where it is leaking, and there is no description that tells me if valve was left outside and cracked with freezing water, or if the valve is 10 years old, or if exposed to hard water deposits or minerals in the water, or particulate has scratched moving parts, or high water pressure, or if wd-40 spray lubricant dissolved the o-ring, or if the valve cracked from an impact, or if exposure to sun/heat has made the plastic brittle.
From fixya standpoint, gardena is the most problematic watering device.
Apr 29, 2011 | GARDENA Water Timer #31169-4
Hi, my insinkerator hot water dispenser is leaking from the bottom screw. It is a couple of years old. Moder SST
My unit is 3 1.2 tears old. It started to delay the flowing of hot water. Today I held the lever down until hot water came out but I noticed water leaking from inside the unit. I figured that the tank failed, and since it was over 3 years old I decided to open it up. What I found was that there is a plastic tube at the top of the unit that was very discolored and brittle which developed a crack. when I touched it it completely severed. I called the Insinkerator hotline at 1800-558-5700 and they told me that opening the unit voids the warranty. I said that it appears to be out of warranty and I needed just the plastic tube for repair. The per on on the phone said that as a one time courtesy that a new unit would be shipped to me free of charge and that I could install it myself or they will have a tech do it. I opted to do it myself. Hope this helps
Nov 05, 2010 | Emerson InSinkErator W-152 Point-Of-Use...
When I first begin to iron, water comes out in wide streaks on the garment Sometimes the water will leak out the bottom of the iron, not from the plastic container, but out a crack in the metal part on the...
It sounds like the iron that I had about 8 years ago. I would return it before the warranty runs out and get your money back. I would recommend a phillips G4430. you will love it
Sep 09, 2009 | Rowenta Irons
Water leaking
it could be the boot seal, (rubber piece that joins the tub to the front panel). the boot can get a hole in it or it can pull away from the tub if the clamp loosens. if it is the front of the outer tub that is cracked the manufacture did warranty the tub for ten years prior to 2006. check your owners manual as that is what the company has to honor. they only cover the part not labor, and in the usa only. i hope this helps.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking
You have to open it and clean out the water passages.
Jul 23, 2008 | EdgeStar Portable Air Conditioner Heater
Leaking Kenmore dishwasher
if you are very careful you can reseal it with a soldering iron as it should be a sealed cabinet. i have seen one seald with a cheap sealr and the cabinet turned orange.
Feb 12, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Washer leaking water from bottom
Probably a main tub seal, big job!
Nov 16, 2007 | Maytag MAV7600 Top Load Washer
EdgeStar AP14000HS Portable Air Conditioner Logo
252 people viewed this question
Top EdgeStar Heating & Cooling Experts
John Tripp
John Tripp
Gene Tuck
gbob59
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
