Question about Acer Aspire One PC Notebook
Laptop Touch Pad will not work
Plugged in keyboard and mouse and laptop keyboard all work fine. Touch pad does nothing.
    President:
  • 2,571 Answers
If you plug usb keyboard onto your laptop it will probably turn the touch pad off.
If no other keyboard is attached there is usually a switch to turn off the touch pad.
also if you attach a mouse this may disable the touchpad so you dont move the mouse pointer when you are typing
Posted on Jul 10, 2010
Free laptop, broken mouse pad.
Keep using the wireless mouse as if the on board pad is broken, it could be an expensive job but try new drivers first.
Nov 12, 2015 | Computers & Internet
Hewlett packard manual
Have you put the battery back in the laptop? Your laptop probably just needs charged. When it blinks it means it needs charged. Is the battery in the laptop correctly? Try putting it on charge. Hope this helps.
- Nathan
Jan 16, 2014 | Computers & Internet
I HAVE BLOCKED MY CURSOR ON ACER LAPTOP BY MISTAKE
When your mouse pad is not functioning, it's hard to get most anything done on your computer. The fortunate side to all this is that getting a mouse pad to work again on a laptop is not an overly complex procedure. A few troubleshooting techniques will quickly lead you on your way to productivity again.
Examine your mouse pad. Dirt and grime can affect performance and slow down mouse sensitivity, if not shut it down altogether. Make sure the surface of the track pad is clean and that there is nothing that has managed to get beneath it or around any trackball buttons that could affect the pressing and depressing of the component. Check to see if your mouse pad has been turned off. If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad. To enable your mouse pad on a Windows PC go to the Control Menu. Under the Printers and Other Hardware option, click on Mouse. Then, click on the tab on the top of the pop-up menu that says Device Settings. The touch pad for your computer should come up as a selectable option. Click on it and you will see the option to enable your device, then click OK. If this does not work, proceed to the next Step . Check the manufacturer of your laptop (for example, Toshiba) and then navigate to their official website. Find an area for Software and Drivers, and move on to that area. Enter your laptop number (check your documentation/manuals and/or the bottom of the computer) and look through the drivers that are presented as a result of this number input. It could be that your mouse pad simply needs updated drivers. Find the driver that corresponds to your computer and mouse pad (for example, most Acer laptops use a Synaptics touch pad). Then, click on download. Once the drivers have downloaded, double click them to ensure they install, restart your laptop, and your mouse pad should be working again. Hope this helps.
Jan 08, 2013 | Acer Computers & Internet
My laptops mouse is not working
IF you are referring to the external mouse attched to your laptop
then please check the same mouse with some other systm to verify if
the issue is with the mouse or with the laptop.
if the mouse is working fine with other system, then you need to
contact the service provider of your laptop.
Otherwise you have to buy a new mouse.
If you are referring to the touch pad of your laptop not functioning
properly, then please check the touch pad settings through control panel.
otherwise please shut down the laptop.
Take out the baterry out & wait for atleast 1-2 minutes.
Reinsert the Battery in the laptop & reboot the laptop.
Check if the mouse is working fine or not.
If the problem with the laptop still persist, please contact your
laptop service provider for further support.
Hope this will help you in resolving the issue.
Cheers!!!
Vivek
Dec 26, 2009 | Computers & Internet
Acer aspire3100-1033 laptop the mouse touch pad and keyboard don
when you start your system , press f1 continously on your keyboard to check ur cmos settings if they are not disable
Oct 24, 2009 | Acer Aspire 3100-1405 Notebook
Lenovo n500 laptop ... mouse pad not working
The mouse pad maybe faulty or the ribbon cable from the mouse pad to the motherboard may not be properly connected. Reseat this cable.
You can connect an USB optical mouse to the laptop. I prefer you use a USB mouse all the time over the mouse pad.
Sep 29, 2009 | Lenovo 3000 N500 Notebook
Re toshiba techra 8000
Some laptops have a touch pad between the keyboard and the edge of the laptop. This works like a mouse except you slide your finger around the pad to move the mouse pointer and the buttons next to the touch pad are the left and right buttons.
Other laptops have a small round button in the middle of the keyboard which is a mini joystick and it is used to move the mouse pointer around, it will have a couple of mouse buttons at the botom edge of the keyboard.
You can connect a normal mouse to your laptop, it is mush easier than using the laptop's touch pad or mini joystick.
Sep 16, 2009 | Toshiba PA3121U - Satellite Pro 6000,...
Laptop touch pad mouse does'nt work while charging
my toch pad dont work when my laptop is charging i have inspiron 1525
Feb 26, 2009 | Dell F3534 Touchpad
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
Mouse touch pad
I couldn't find an answer online, I have a Toshiba satellite with Vista and the clicking wasn't working on the pad. I found the answer....
open control panel...
hardware and sound....
mouse....
the tab Device Settings
click Settings
click Tapping on the left
click the check box enable tapping
and for everyone with problems with nothing working on the pad at all hold down the FN key next to the control key and press F9
Feb 05, 2008 | Acer Aspire 3000 Notebook
Acer Aspire One  PC Notebook Logo
1,171 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
