Question about Funai F42PDME 42 in. Plasma Television
Emmerson Flat Screen TV one of transformer that light screen
Emmerson LC 320em 93
recondition by Funai corp
Part number : LTZ3PC0XB004
JS HVT-133 080126
3 Suggested Answers
  • 12 Answers
SOURCE: Funai TV will not stay on. It turns on for 1 second and then turns off. Red standby light blinks on and of, what can I do?
Either the power driver board is faulty, or it has a humidity sensor in it, which turns it off. Move it to a very dry place for a few days, then try it again and it might work.
Posted on Jan 19, 2015
Testimonial: "Ive removed the back cover and i see only 2 boards the main board and the power supply board. The TV has been in a temperature controlled bedroom. Paid 99 dollars for it brand new, think its worth the repair?"
  • 1552 Answers
SOURCE: I have a funai 32" flat screen that will flash but won't completely turn on
Unless you are a qualified technician, you cannot fix it.
Instead, take it to a qualified technician, and ask him/her whether it would be cheaper to REPAIR or to REPLACE it.
Posted on Feb 14, 2015
Message says see first page of manual
Do you have a coaxial cable attached to the antenna in on the TV? The TV has an ATSC (digital OTA) tuner and a NTSC (analog OTA or CATV) tuner. The initial setup wants the incoming antenna in signal to be present (this is the only message on the front of the TV manual).
This TV was built by Funai and the manual is available from Funai's support page: http://www.funai-corp.com/support/manuals.aspx . Since Funai makes TVs for a number of brands, the best option is to search for the model number (leave off the brand name) in their search box. The direct link to the IWT3206 manual is http://www.funai-corp.com/6pdf/om/IWT3206.pdf .
I hope this helps.
Sep 17, 2011 | iLO IWT3206 TV
We just brought a Sylvania Flat Screen TV Model no. LC320SLX Serial no. DS2A1006154179 We had the TV hooked up and it was working fine and then this morning it won't cut on. We thought it might have...
Hello; I am John at J. D. Electronics, Poland Maine. This problem is usually caused by defective inverter transformers. These sets are made by Funai Corp. I have now replaced 100's of these. They are about $5 each and most sets have 5 to 8 of them. Replace them ALL at once. There are many other problems I have found that require replacing whole PCB's , so this is only a guess. John
Oct 13, 2010 | Sylvania LC320SLX 32 in. LCD TV
HAVE A VERTICAL PROBLEM PICTURE IS ONLY FOUR INCHES HI IN MIDDLE OF SCREEN
Sounds like the settings are off.
call: FUNAI CORPORATION
Customer Service
Tel :1-800-605-8453
You will need you model & serial numbers when you call them. You can also go to their web site but you will get faster help by calling them.
Jul 29, 2009 | iLO IWT3206 TV
It being emerson 32" hdtv lcd turns on but immediately turns off
This is Emerson's #1 problem.
The Inverter Transformer on the power supply/backlight inverter board goes bad. It's what powers up the screen for your TV. When the part goes bad, it doesn't have enough juice to power the screen and the TV automatically turns off. You have 5 Inverter Transformer on your board.
You can fix the problem by replacing the whole board or replace the bad Inverter Transformer.
Here's where you can get a new board for a good price:
http://www.shopjimmy.com/catalogsearch/result/?q=lc320em9+inverter
Or, here's where you can get replacement Inverter Transformers:
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
Jun 17, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Sylvania Lcd 32 in.
Is it under warranty by chance?
What is happening is when you turn on the TV, it's trying to power up the screen at that moment. If it can't power up the screen, it will turn off automatically. This is what they call, "Protection Mode".
All the TVs made by Funai (Emerson and Sylvania) are having the same problem. The Inverter Transformers needed to power up the screen are somewhat low quality and burn out easily. I'm sure of of them burned out.
Your TV, I believe, takes 6 of those things to power the screen. And they are all on one circuit board.
If the TV is not under warranty, then let me know what the board number is on that circuit board. The board inside the TV should have maybe 6 connectors that hook up the screen. I may be able to track down a replacement board for you.
Apr 25, 2009 | Sylvania LC320SS8 32 in. LCD Television
CANT USE DIGITAL TV OR HDMI MODE - SCREEN NOT SIZED
Give FUNAI a call they can walk you through the problem. There info is...
FUNAI CORPORATION Customer Service
Tel :1-800-605-8453
Feb 15, 2009 | iLO IWT3206 TV
Emmerson HDTV f32
The failure with this LCD might be due to a failing power supply or backlight inverter board. Since your TV is less then a year old, I would suggest to call the manufacturer to get it fix under warranty.
Good Luck.
Jan 17, 2009 | Televison & Video
Need owners manual
go to this website for manual
www.orionsalesinc.com/docman
Dec 14, 2008 | iLO 3200 32 in. LCD Television
Black screen after 1-2 minutes.
Hi, I just fixed one I bought on eBay with the same problem. My problem was caused by the screen backlight inverter. Fortunately I had one from another TV I bought last year on eBay. The repair only took about 15 minutes. Your best bet is to contact Funai Corp. and really complain even if it is out of warranty. They make Emerson, Funai, Symphonic and Sylvania and all the parts inside are the same (from the same years). If that don't work look on eBay for one with a broken screen or some other damage, call your local dealer and see if they have the inverter from a broken TV or ask around. We have a freecycle group in Michigan that recycles things rather than throw them in landfills you may have one in your state too !
Good Luck,
Jul 15, 2007 | Sylvania 6620LDG 20 in. EDTV-Ready LCD...
Funai F42PDME 42 in. Plasma Television Logo
127 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
