Question about Samsung LN-S3251D 32 in. LCD HDTV
I have Samsung ln-s3251d lcd tv. When powered on the screen flashes once then blank. Understand this points to a bad inverter. any additional troubleshooting to confirm bad inverter? and what is the correct part number/ supplier.
SOURCE: Bad transformer on Inverter Board
for me I think I'm gonna try Decision One a certified Dell fixer upper. I looked at my inverter and there were no burns that I could see. My problem is different from Headstrongs come to find out. Dell w3201c is the model number, it has samsung on parts under the hood....
good luck
Posted on Jan 15, 2008
SOURCE: Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Posted on Mar 14, 2009
Fixe_You
  • 1800 Answers
SOURCE: ln-s3251d sound oke no video
check connections
Posted on Jun 05, 2009
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Posted on Sep 22, 2009
budmrtn
  • 11361 Answers
SOURCE: LN-S3251D mode not suported when
That means the video source resolution is too high for the TV to display, you need to lower it.
What is the HDMI attached to?
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Nov 07, 2010
SOUND NO PICTURE
Yes your right, THE BACK LIGHT INVERTER BOARD GONE BAD
Oct 17, 2012 | Samsung Televison & Video
When i turned the tv on today the picture came on with sound but then turned purple with vertical stripes. When i tried again, the screen remained black but still had sound. When I turned it off and back...
Youy may have bad T-CON, Power supply, LCD panel.
Learn about T-CON/LCD panel failure mode:
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
PDF download: http://www.mediafire.com/?zzjygannjty
Inside the TV:
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/Samsung%20LN-S3251D/
Try this when the screen goes black:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 10, 2011 | Samsung LN-S3251D 32 in. LCD HDTV
46" LCD Samsung TV Model# LN-S4692D I have no picture
The back light inverter board may have gone out or it is not getting the 24vdc from the power supply module. Start checking for voltage feeding the inverter board.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN-S4692D+
Jan 07, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung 32 lcd tv backlight off after 4 sec. audio ok
If your TV is staying on and you hear audio after the picture goes dark, then you have a problem with a CCFL or the inverter circuitry that drives them.
Most likely an inverter problem.
Like a bad xformer (usually fogged up plastic wrapper)
Or a bad cap (bulged, swollen, cracked)
Or maybe a shorted IC or transistor (test for short circuit between the different pins of the device)
Oct 08, 2009 | Samsung LN-S4051D 40 in. LCD Television
SAMSUNG TV
your tv inverter is bad
Aug 29, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung LN-S3251D
We have the same problem we have had ours for 2 months, went to turn it off the and the tv froze, could not turn it off or change channel. We had to turn it off at the power point, now it will not turn on at all. The red light flashes but no picture.
Jul 05, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Hi.
This is very common with all makes of lcd tv unfortunately the transformers are near impossible to get hold of on there own.
Your best chance is either look on Ebay to see if anyone has A scrap complete tv same model for sale.
Or look for invereter board for sale.
Just to give you some idea of what you are looking for this is a link to A site in the UK that sells inverters.
http://www.chsinteractive.co.uk/electrical-components/lcd-television-inverters-etc.html
Chris.. http://dysonmanuals.llc.nu/
Dec 27, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung LN-S3251D 32 in. LCD HDTV Logo
75 people viewed this question
Henry  Thomas
Henry Thomas
