Question about Dyson DC18 all floors Bagless Upright Cyclonic Vacuum
How do I replace the power cord on the dc dyson 18?
How do I replace the power cord on the dc 18?
5 Suggested Answers
VacuumRepair
  • 438 Answers
SOURCE: need to reclace power cord
Greetings,
I have gone ahead and taken pictures of how to change the cord on a Dyson DC07 upright. Here's what you'll need to have handy in order to complete this repair:
- T15 Torx Bit Screw Driver
- Dyson DC07 Power Cord For All DC07 Models, Part 905449.
- A 2mm or Smaller Flat Head Screwdriver (width of the tip)
- Needle Nose Plyers
- Patience (haha)
The cord above is actually a link back to our site if you have yet to purchase your cord. We carry most every Dyson part.
IMPORTANT: MAKE SURE YOUR VACUUM CLEANER IS UNPLUGGED BEFORE DOING ANYTHING ELSE!
Step 1. First thing you'll want to do is to unwrap the cord from the machine, and remove the handle from the upright part, then slide the hose all the way down the wand, and remove the hose from the handle assembly completely and set it aside. Also remove the dust bin assembly completely from the machine as well.
Step 2. Once you've remove the handle from the machine I find it easier to work on if you lay vacuum on it's back, with the switch button facing upwards. Now remove the T15 Torx bit screw that is directly below the switch actuator. I have circled the location of this screw in the picture below:
Step 3: After you have taken off the screw, you're doing to need to remove the switch box housing from the vacuum that the screw was securing. Simply use your flat head screw driver, and pry the two small arms upwards. Be careful when prying, the plastic components on Dyson vacuums are really cheap quality plastic, and I can't tell you how many times I have seen these plastic parts break. Here's a picture of the location of where you should pry the switching off:
Here's what the vacuum should look like after the switch housing has been removed:
Step 4. Use your needle nose plyers to remove the terminals from both of the switch poles. Also be careful when removing these terminals, don't force it or it will break the pole right off of the switch, and you'll then have to replace the switch along with the cord. Also you'll need to remove the two white wires that are connected together apart, also using your needle nose plyers.
Step 5. After you've removed the two terminals connected to the switch, as well as the two white wires that were connected, follow the electrical cord up until the point that it enters the vacuum cleaner to the rubber cord protector. Lift straight up on this cord protecter to remove it from the vacuum.
Step 6. You'll have to now slide the cord out through the cord protector so that you may install the protector on your new cord. Unfortunately as you'll see, your new cord does not come with the plastic terminal protectors that are on the end of the wires, so you'll need to take off these plastic ends on both the black, and the white wires that come from the cord. The other wire that you see in there that has a white wire with no plastic cover, and a black wire that does have the plastic terminal. There's no need to remove the plastic terminal from the wire that runs down into your motor, just leave these alone. If you look closely at these plastic terminal covers, you'll see that one side of them have two little ridges on the inside, also that the bottom is flat, and the top rises upwards on one end. To remove these plastic parts, use your 2mm flat head screwdriver and insert it through the top part that has the two ridges on the indside. While your screw driver is in as far as it will go, lift upwards away from the wire while pulling out the wire at the same time. Repeat this on the other wire as well.
This is how the wires look like without the terminals:
Step 7. After remove the plastic terminal covers from the wires, pull the cord through the rubber cord protector and remove your old cord. Open your new cord, and now you'll have to feed the two wires through the cord protector. Simply push the cord through the ribbed end of the cord protector. You normally can push the cord hard enough so that the ends of the wires will come out the other end fairly easy. If the wires don't come out, use your needle nose plyers to pull the metal ends of the wires through the rubber cord protector.
Step 8. Reconnect the wires to the switch, as well as connecting the two white wires together. Here's how the wiring should look like when done properly:
Step 9. After reconnecting the wires to the switch, and to the other white wire, you'll need to put the switch back in place, along with the cords, and the cord proector. You can see little channels that the cords actually sit in to keep them from pulling out. Place both the wire on the bottom that goes to the motor, as well as the electrical cord into these channels. The two white wires that are connected together go to the left of the switch. Here's how it should look like when you're finished:
Simply put the switch housing cover back over the switch and cords, and screw the Torx bit back in, and then test the vacuum to make sure that the cord works.
I hope that this repair was helpful to you with fixing the cord on your Dyson DC07. If you have any questions about this repair, or need further help on replacing the cord, please use the Clarification Request, or leave a comment on this repair and I'll be more then happy to help you further. If this was helpful to you, please be sure to rate the review helpful by clicking the thumbs up incon in the top right hand corner. Again, if you ever need any supplies for your Dyson, we do carry most parts and accessories on our site under our Dyson Parts Section .
Thank you,
Chris J.
GoVacuum
Posted on Apr 03, 2010
Dysonteam
  • 167 Answers
SOURCE: My Dyson DC-18 won't click and stay in the upright
Hi its Darran at Dyson.
It is difficult to confirm what may be causing this, however its worth ensuring that when you lock the machine back up into the upright position position, that you push the handle slightly forward when you try to do this to help the pedal engage.
If this is not working, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 19, 2010
Dysonteam
  • 167 Answers
SOURCE: Dyson Slim DC 18 all floors has no suction from
Its possible that the brush bar is not turning when you release the head into the vacuuming position. Please ensure you complete a full blockage procedure as per your user guide to see if this resolves the problem. If you do not have a copy of the user guide to hand, please visit the Support section on our website at www.dyson.com.
Alternatively, if you still need some help or advice with your Dyson, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dysonteam
  • 167 Answers
SOURCE: My Dyson dc 18 slim extender wand has NO suction.
To clear the blockage remove the wand/hose assembly from the machine and the remove the wand from the hose. If the blockage is in the wand handle, you will ned to use a narrow stiff object long enough to poke through it to try and clear it. If the blockage is in the hose, you should be able to remove it completely from the machine then this will help you remove the blockage.
Should you need any further help or advice, please call us on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Posted on Apr 20, 2010
My dyson dc 33 wont start
Hello, this is Ava with Think Crucial.
If your vacuum doesn't turn on, make sure that plug is fully inserted into a fully functional electronic outlet. If it still not turning on after verifying this, it could be that the power switch is malfuntioning. You may need to replace the power switch by opening up the handle of your vacuum. I suggest to refer to your manual on how to replace the power cord or contact Dyson for troubleshooting steps. 1-844-679-1647
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc33
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Oct 31, 2016 | Dyson Vacuums
Dyson DC 18 slim Brush bar stopped working, complete loss of suction motor overheating, need help ?
A short or restricted brush roll may be causing problem there. Overheating is indicator filters may need replaced.
Mar 19, 2016 | Dyson Vacuums
How to replace Dyson DC17 Brush roller motor
http://www.dyson.com/support.aspx is a good place to start.
Mar 01, 2015 | Dyson Dc-18 "slim" Upright Model...
How to replace heap filter?
There are information videos on YouTube . com showing step by step replacment
Aug 07, 2014 | Dyson Dc-18 "slim" Upright Model...
My dog chewed the plug off the power cord, is there a way to replace it. I love my dc-17 dyson animal
Yes. You can splice the cord together. But when you pull it it will want to separate, so when you splice it add something ...like a wire tie..super glue it to both sides before you tape the splice. If it is the whole cord you will have to take it apart and make new stripped ends and just remove the old piece..put the new end on. This is not as easy as it sounds, I have done it but I am handy with tools and a little common sense.A handy man can fix it for you.
Oct 29, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
I need a parts diagram of a dyson dc 18 that I can read. Please help.
Sorry we do not have this diagram. Contact Dyson, whom I suspect is not going to be very helpful based on previous experiences
Oct 11, 2012 | Dyson Dc-18 "slim" Upright Model...
Dyson DC18 all floors Bagless Upright Cyclonic Vacuum Logo
668 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
