Question about Sony STR-DE595 5-Channel Amplifier
I have an STR DE935 and the last few days if i turn the volume up about half way it kicks out and the word protector flashes in the screen , HELP
  • mstrbreze Jul 10, 2010
    thanks ,i'll have it checked out
    President:
  • 4,070 Answers
Hi! IF the protect flashes then it will mean it reached its limit. If its not what its like before then something is wrong. Its gotta be a blown or faulty capacitor in the mainboard that needs to be replaced to get the maximum performance back again. HOpe this helps and have a good one!
Posted on Jul 10, 2010
My STR-DE925 reciever isn't giving me any sound. When i turn it on everything works like normal, kicks on, and there is a click; but after a few seconds the display switches from whatever input it was on...
check speaker connections.sounds like the system is trying to stop some thing more serious happening by shutting itself down.a pain yes but saves blowing something up.if no luck,then definately send in for repair
Oct 17, 2010 | Sony STR-DE925
I lost the remote for str de935, where can i get a replacement? Robert
Required remote control RM-LJ302 (part number, 141829311) is available in Part Store but price is bit high.
Thanks.
Oct 15, 2010 | Sony STR-DE935
Protector comes on
Check on the output of the set, It can be short. remove the power supply from the section to confirm.
The receiver must be discconnected also from the speakers to confirm if there is any short on them
Sep 15, 2010 | Sony STR-DE935
I have to replace 2 fuses 8Amp 125volts from a sony reciever, but I can't find it to buy , do you know any site to order on line or if I could use 8Amp 250volts?
fuses have different sizes even though they have the same rating's, the best remedy to do is, do you any stranded wire, cut one piece out of the whole strand and solder it on the fuse housing that will do the trick.
Jun 09, 2010 | Sony STR-DE935
How to know Amp and volts Fuses of a volume board RECEIVER SET-DE
Power output divide it by 110
example 600 / 100 + 5.45
you need to replace it with 6 Amperes or the closest as long as it is not lower than 6
Jun 06, 2010 | Sony STR-DE935
Sony STR-DE915 Receover, flashing "Protector" when power on
Serious problem either in the power supply or output stages of receiver.
Sep 16, 2017 | Sony STR-DE915
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
Sony str-de935 protector flashing have to shake amp
Sounds like a bad solder connection. check around input jacks and tighten the screws that hold the circuit boards and the heat sink.
Jan 31, 2009 | Sony STR-DE935
Protected
Oct 23, 2008 I have the same "Protector" problem. There is mention of this on Sony's website:
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  1. Check the speaker wires and speakers for proper connections.
  2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
  3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
  4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
  6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
I followed their "advice" to troubleshoot...now my unit's been in the shop for a couple weeks.
I called for status today 10/24/08 and was told that there is a "backorder on a part". My repair
shop cannot estimate when the "part" will be available.
SO...I suspect a component failure and since Sony does not have the part, the questions are:
1. Is there a delay in Sony getting the needed part from the manufacturer (if it's not Sony)
2. Are there so many occurrences of this problem that Sony can't keep the the "fix part" in stock!!
Time will tell!
Dec 02, 2007 | Sony STR-DE935
Sony STR-DE595 5-Channel Amplifier Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
