Question about Sony KP-51HW40 51" Rear Projection Television
Sony KP-51HW40 Screen gets bright green & flashes
After set has been on for about 30 min. you can see the green get brighter then it flashes and goes back to normal once this has started it will continue until it shuts off. I had the retrace lines and adjusted that but now I have another problem, Any advise? is there anything else that may need to be adjusted and is it something I could do? Stumped again in NC
  • william ward Jul 10, 2010
    Thanks again for the great advise with the cost for finding a service tech you have saved me alot of money.
  • 4,889 Answers
I have seen this one before. It is caused by voltage spike on the green CRT. Did you adjust the green color voltage to remove the retrace lines?
Posted on Jul 10, 2010
  • 6 more comments
    This problem started a month ago now I'm wondering if I may have adjusted the focus on top I do know the retrace lines went away and it was fine for awile but I wasn't watching it much seems the longer it was on was when it would flash. Could I try to turn the focus on the green a little to the left? I do know when I asked for assistance last night I turned the bottom screen to adjust but I wasn't seeing the retrace lines It's fine until it warms up after 30min or so then flashes so it does sound like a voltage problem. And if I adjusted the focus the first time and not the screen I may have created this problem. Got to love it. Hopefully I haven't damanged anything else but again I'm not certain if I did the focus. Any advise about turning the green focus to the left? Thanks again
  • eagle338
    eagle338 Jul 10, 2010
    Yes it was.
  • eagle338
    The try turning it in the opposite direction such that the lines are not there and the spike does not occur. My guess is that you turned it too much! Don't know if the spike has damaged the resistors on the CRT board but I hope not. Adjust it keep it on for half and hour and see if the spike occurs again.
    Last night I turned the screen control on the bottom ( green) all the way to the left and gradually to the right until I saw the green retrace lines and then back to the left until they went away I thought this corrected it but after awhile you could notice the color starting to get brighter and then flash, I'll try to turn it back to the left some more and keep my fingers crossed. Thanks again I will let you know what happens. If this doesn't work what would you think needs replacing I do have experience in soldering and working on circuit boards. I do have the service manual but not an oscilloscope.
  • eagle338
    You do not need an oscilloscope. When this kind of thing happens its only the resistors (that go boom) on the small board attached to the back of the green CRT. Shouldn't be too hard for you considering your experience level. I hope it had not progressed to that level though.
    Thank you for your help. If it did damage the CG board I found one online for $24.00 that sounds better than trying to find the faulty resistor. And I also found the tubes already assembled for around $129.00 Again thank you for the help.
  • eagle338
    You are welcome! Thank you for using Fixya!
My Sony big screen rear projection TV model KP=51HW40 produced 2002 screen flashes red then shuts off. We can turn it back on and it will run for 30-60 minutes and then it repeats red flash. Is this
The Problem you are having is a Cathode to Grid Short in the Red CRT,When it Shorts the screen will Go all Bright Red and shut Down,The Best fix Would Be to Replace the Defective CRT (GUN)
Dec 30, 2011 | Sony Televison & Video
My Sony KP-51HW40 is flashing a green screen and then going back to the image, then it gets more frequent, and eventually cuts off, i'm guessing it's a heat issue... but where?
Your Green picture tube is arching / Failing. The only way to fix is to remove the tube and ship it to a company that rebuilds tubes, but this would not be cost effective.
Apr 19, 2011 | Sony KP-51HW40 51" Rear Projection...
Turn tv on,picture good for 4 seconds,then green curved line like a rainbow all green,then 4 green sequence flashes,picture goes out theN volume continues for 2 seconds then out front red power light then...
This is a set with bad picture tubes-not available except on rebuild basis.
Are you seeing bright green screen and then set shuts off?
Let me know so I can help--8 blinks is AKB error.
SD TECH
Sep 15, 2010 | Sony KP-51HW40 51" Rear Projection...
KP-51HW40 Sony 51" Fades to blue screen
The service manual on page 8 shows how to adjust the Red/Blue/Green screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Aug 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-51HW40 - Picture not Clear
Your problem is a typical convergence problem that happens on almost every tube type projection TV set ever built. There are two Convergence amp IC's that need to be replaced. If you have no TV repair experience, play it safe and call in a pro to assist you in this. Good Luck
Apr 29, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
55 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
