Question about Craftsman Garden
Repalce blade on 700 series craftsman lawnmower 917.374541
    President:
  • Craftsman Master
  • 1,545 Answers
Tilt the mower back in a direction that brings the front (spark plug end) of the engine up and the back of the engine down if possible. This keeps the oil from going places it doesn't need too.
Under the deck of the mower you will find the blade bolt It will be in the center if the blade and should be a hex-head bolt Around the 1/2 " size. You will need to either jam the blade where it can't turn the motor while you attempt to loosen the blade bolt or enlist a helper wearing gloves maybe to hold the dull side of the blade still (if you can't hold it yourself). For easier removal of the blade bolt the next time around, coat the threads with Permatex Anti-Seize Dry Graphite Compound. You won't have it stuck or rusted next time.
Posted on Jul 11, 2010
Lawnmowers: How to replace drive cable on Craftsman 700 series Model # 917.374551
Try SearsPartsDirect.com or Parts Tree Repair Clinic they may have a video.
Mar 18, 2018 | Craftsman Garden
When I engage my blades the engine dies on my craftsman lt4000 riding lawnmower
Try checking your seat safety switch by TEMPERARLY bypassing it..try the blades if ok..your seat switch needs replaced..good luck..
Sep 11, 2015 | Craftsman Garden
How to change the belt on a craftsman rear wheel drive lawnmower
open drive cover take plug out roll belt off pully by pulling it to the side and hand turnig the blade after comes off drive remove blade and take off belt to reinstall do reverse
Aug 28, 2014 | Craftsman Garden
I have a brand new craftsman 190cc lawnmower and the pull cord will not pull out
If it's new sometimes the manufacture puts a safety block to hold it from moving during transit. Check for this. See if the blade will turn and if not see if there is a seized area. Is the blade jammed against something.
Jun 30, 2014 | Craftsman Garden
Cant pull string on lawnmower
if motor is lock up pour oil in clinder and work the blade back and forth till it unlocks
Apr 28, 2013 | Craftsman Garden
My Craftsman Series 550 Lawnmower was working fine and I decided to check and clean the airfilter and carburetor. When I tried to restart the pull cord is stuck and won't allow me to pull it. I have...
i suggest you pull the housing off for the pull cord and see if it pulling fine if it does see if the brake is of on the motor i would bet the brake is not releasing
Jul 17, 2017 | Craftsman Garden
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
42 deck craftsman riding mower. how do you get blades off? md 91721880.
On most riding lawnmowers, you can remove the blades reaching underneath the deck while the deck is set to its highest position. This may not be possible on lawnmowers with three blades; however, most 42 inch mowers have two blades.
The blades are usually held on with either one or two bolts (on each blade). Oftentimes, too, there is a lock washer underneath the bolt.
If you have auto ramps, it might help to push the front end of the mower up on the ramps. This can give you more room to access the blade bolts.
If the blades have not been removed before, those bolts can be on really tight. You might need to use some kind of breaker bar on your wrench to give you more leverage.
Oct 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
573 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
