Question about Lexmark X2500 All-In-One Printer
Installing ink cartridges lexmark x5650
I have a new printer without any instructions .. where do the cartridges do and how are they installed?
    Scholar:
  • 66 Answers
Go to the Lexmark website and read or download the user manual and quick start guide for the x2500 from here.
http://www.lexmark.com/publications/pdfs/2007/2500/en.html
Posted on Jul 10, 2010
Memory info retrieving from lexmark x5630 fax machine
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing at the instance of receiving the fax. When this happens, try to replace the cartridge(s), *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink or empty cartridge(s). After the new cartridge is installed, close the printer cover and press the OK button. Your printer should then print the fax stored in the memory.
*Make sure not to navigate away from the "fax sent to memory" message, otherwise, data will be lost.
Dec 30, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
How to print faxes from the lexmark x5630 which is stored in the memory
Dec 30, 2011 | Lexmark X5650 All-in-One InkJet Printer
I dont know how to change the ink cartridge on my lexmark?
For more detailed instructions on how to change/replace the ink cartridges in your Lexmark printer, please refer to the Lexmark X5650 User's Guide. Turn to page 111 - Maintaining Print Cartridges.
I hope this information has been helpful.
Nov 30, 2011 | Lexmark X5650 All-in-One InkJet Printer
How can I install black cartridge only without printer stopping me from printing
The Lexmark X5650 printer requires both the black and color cartridges to be inserted in the printer to continue printing. Both cartridges must have ink in them and not empty.
Sep 03, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
Where is the cartridge located on printer and how do i re install a new one black in colour
This article in the Lexmark website on How to Change the Cartridges on Lexmark Inkjet and All-In-One Printers will give you a step-by-step instructions.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the cartridge carrier to the center of the printer. Remove the used cartridges. Load the new cartridges. Close the cover. Plug the printer back to the power source.
Feb 10, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
We have a X5650 Lexmark printer. The ink cartridges were both replaced with certified cartridges (parts 36 and 37xl) . When installed the printer does not recognize that the cartridges have ink and...
It could be that the cartridges are not inserted properly in the carrier or just needs cleaning. Try to remove both cartridges from the printer and manually clean the nozzles. You may refer to this article on How to Clean the Print Cartridge Nozzles and Contacts Manually. Then reinsert one cartridge first and close the cover. If no error appears, reinsert the other cartridge. Replace whichever cartridge is causing the error. You can also try the Clean Cartridge function on the printer by pressing the Setup button -> Maintenance -> Clean Cartridges. It will then print the clean nozzles test page. If error continues, replace the faulty cartridge.
Jan 20, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
My lexmark x5650 ran out of ink and i replaced the cartridges and it keeps saying to replace them. they are new please help.
I have had same problem with same model. As ink is used there are tiny internal electronic fuses which 'blow' as ink is used and cannot be reset. Sorry you need to buy original cartridge.
ianparronline.wordpress.com
Jan 03, 2011 | Lexmark X5650 All-in-One InkJet Printer
How do I install a new ink cartridge?
Use the maintenance key to depress so that the printer brings the head to mid position. Now remove the old ink cartrdge by pushing the locking lever , then insert the new ink cartridge into the carriage.
Make sure that you do this gently when removing the ink cartridge.
Once finished do a test print , or try to do a head self cleaning.
Sep 19, 2010 | Lexmark X5650 All-in-One InkJet Printer
I just set up a new X5650 printer, and after a couple of print jobs, the printer says black and color ink low. I changed to brand new cartridges, and it still says the same thing. What should I do?
Some printer-vendors sell "half-full" ink-cartridges, to get you to _sooner_ buy replacement ink-cartridges.
Also, some printers need to be "told" (via software) that the ink-cartridge has either been replaced or refilled. Your printer could be one of those printers.
Aug 24, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
I have a new Lexmark X5650. for the first time I changed the black ink cartridge with an original 36 as indicated, and yet it tells me I am out of ink! Help! Thank you
Remove the cartridges from the printer. Close the cover. Unplug the printer from the power source and leave it unplug for now. Then, wipe the nozzles of the cartridge using a damp paper towel. Plug the printer back to its power source. When the printer's ready, re-insert the cartridges. Close the cover. The printer will print an alignment page. Just let it print the page without cancelling it. If that doesn't resolve the problem, try pressing the Settings button on the printer control panel. Go to Maintenance, then hit ok. Select Clean cartridges, then hit ok. That will force inks out of the cartridges and also cleans the nozzles. You can check ink levels by pressing Settings on the printer control panel. Then go to Maintenance, select Check Ink Levels. If ink level is still not recognized, have the ink cartridge replaced. You probably got a defective one.
Apr 08, 2010 | Lexmark X5650 All-in-One InkJet Printer
Lexmark X2500 All-In-One Printer Logo
271 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
