Question about Polaris Pool & Spa
Need instruction manual for SPA -Polaris with ONYX heater
2 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
Need to buy American Water Heater Polaris, 6903768
Make sure you install it correctly. If not can cause exhaust leak and destroy everything in the blower compartment. I have over 450 Polaris heaters installed. "Read the instructions". Depending on which burner gasket you have determines if you will need to use the provided gasket. If the gasket is a graphite type, you need to check and make sure the surface where the hot surface igniter seals against it. The gasket can be missing some pieces, so check carefully. The bracket "must" be installed properly. Again the instructions with the igniter show the correct installation.
Dec 13, 2013 | American Water Heater Polaris, 6903768,...
How do I reverse a lockout of aux 1 polaris?
check to see if repair man disconnected that aux if so plug back in if not go to system set up to activate that aux
Jul 07, 2012 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I purchased a used Hayward H100id1 pool heater and lost the instructions. How can I get a manual with install instructions and how to use it?
Here is a copy of the users manual for these pool heaters. It should have all of the installation info that you need.
http://www.backyardcitypools.com/images/Hayward/H100-Manual.pdf
Jul 04, 2011 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Pentair matertemp 400,000 BTU heater cycles on & off
My pentair matertemp 400,000 BTU natural gas heater cycles on and off before reaching desired temperature. I completely cleaned the DE filter and flow should not be an issue. When running the spa the pressure is 25. When running the cleaning system (polaris pop ups) the pressure is 30. Burner fires for 80 seconds then shuts off, reignites after 53 ceconds.Any tips on what might be the issue with the heater
Apr 04, 2010 | Pentair Mastertemp Pool & Spa Heater Dual...
Heater only comes on when both pumps[filter and polaris ] are on.
If the polaris pump is being supplied before the heater it is taking some of the pressure the heater needs to turn on. You need to adjust the pressure switch in the heater
May 24, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Want to hook it up to my hot tub
Yes, these pool heaters are designed for use with a spa. They are made to accommodate temperatures for both a pool and a spa running off of the same heater. Check the owners manual for specific instructions.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
May 23, 2009 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Looking for wiring instructions for the replacement polaris pump motor. It says it is wired for 240 and I need the configuration for 120. It is polaris booster 3/4 hp pump.
The diagram on the side of the pump shows how it sould be wired for low volatge. I'm having a problem wiring for high volatge and posted the diagram. Use the link to access.
http://www.poolspaforum.com/forum/index.php?showtopic=19400
Apr 24, 2009 | Polaris Pb4 - 60 Booster Pump
Pool & Spa Logo
88 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
