Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
The cleaner will not run! It worked yesterday- but will not run today! It is cleaned out- cannot figure out what to do!
Ok tried the resetting the circuit board thing. there is no button above the on off switch? anyone?
Posted on Jul 29, 2010
  • 52 Answers
Check the Power source that the breaker did not trip or the ground fault switch did not trip. Also check the cord for continuity. The circuit board can be reset. The manuel is online at http://74.84.137.218/website/manuals/RK01A.pdf
The Pool Tech
Posted on Jul 10, 2010
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
My 2004 Chevolet Cavalier was running and started yesterday, but the next day would not start. It would turn over, but not start or run. Just run my battery down, started over, over
Spray a bit of carb cleaner in the air boot, off air filter housing to check if fuel pump went dead. Would be a good idea to check all fuses.
Nov 16, 2013 | 2004 Chevrolet Cavalier
X75 My color won't work. Black is fine. I installed a new one at Xmas and it worked fine. I hardly printed anything.. Yesterday the test page with peacock showed no blue and everything came out yellow. ...
run the print head cleaner tool using the lexmark software. since you hardly used the color the print head nozzle is dried up and needs to be clean.
run the print head cleaner atleast 5-10 or more times as needed.
Mar 12, 2011 | Lexmark X75 All-In-One InkJet Printer
I cleaned my self-cleaning oven yesterday and today it won't heat up. Can you help me out?
hello,
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thank for visiting.
    Oct 09, 2010 | Whirlpool Ovens
    Hello,I just hooked my Baracuda G3 up today.I feel like I followed directions and it does travel around the pool.However it follows the same track each time in a somewhat figure 8 pattern and only cleans...
    Try changing the angle of your return jets in the pool they will have a tendency to set a current running in the pool. This was always what you wanted before to get the water to run past the skimmer but now it will give the cleaner a hard time getting around the pool. If you don't have directionals on you returns Baracuda makes an aftermarket dirvirter to fit most returns.
    Oct 11, 2009 | Zodiac Baracuda Zippy Pool Cleaner
    Cannot remove juice bowl from Juiceman 410. Yesterday it was ok.
    TRY INVERTING IT AND SOAKING IN A
    SOLUTION OF OXI CLEAN AND HOT WATER.
    Jun 28, 2009 | Juicers
    Throttle hesitates early, and also stalls when trying idle-carb
    yes it sure does. get fresh gas too. if you are in the US, get Berrymans B12 fuel additive, double dose throw in tank and run bike til hot, then leave it to stand overnight. see how it is next day. if no better. remove air cleaners and get spray Berrymans , lift up sliders in carbs and spray a ton inside, again leave this overnight to break down the gum and varnish. if neither work then you are gonna have to pull them carbs and open them up to clean.
    Apr 12, 2009 | Yamaha XS 650 H Motorcycles
    Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
    285 people viewed this question
    Top Smartpool Pool & Spa Experts
    Marvin
    Marvin
    Craig Butler
    Craig Butler
    Thomas Perkins
    Thomas Perkins
    Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
