Question about Samsung HP-R4252 42 in. Plasma HDTV
Vertical lines across my entire screen
My tv was working great yesterday, today turned it on and after I turned it on I would see horizontal lines and then a few seconds later vertical lines across the entire screen. In colors (black, red, blue, green, white). If you could please help me. Thank you.
  • 13 more comments
  • rudog3369 Apr 30, 2008
    Lines and no pic !!Not the logic main board you have any picture on screen? Its one of the other boards!! Or the display screen!! I just fixed one that had no picture it was the main logic board! if this helps!!!
  • Sean833 May 07, 2008
    My In-Laws are having similar problems except the lines are horizontal w/picture. They are experiencing bands of colored lines that seem to be more dense in the bottom 1/5 of the picture, getting less frequent as you go to the top of the picture. The top 1/5 seems to be unaffected. Any suggestions? Repair tech coming today.
  • ldc1025 May 29, 2008
    i have pink and green vertical lines all across the tv
  • Anonymous Jul 21, 2008
    vertical lines all over screen, low visablily
  • Anonymous Mar 14, 2014
    TV turns itself on an off
    When i turn on tv their is thick colorful vertical lines throughout the tv
  • Anonymous Mar 15, 2014
    Picture is fine when TV first turned on and then gradually picture is covered in horizontal and vertical lines
  • Anonymous Mar 17, 2014
    green horizontal line across entire screen, tv picture can be viewed
    small green vertical lines across entire screen
  • Anonymous Mar 20, 2014
    My TV looks great when I first turn it on but 5 to 10 minutes later, it begins to show vertical lines on the right half of the screen. The streaking gets worse and worse with more and more vertical lines until the entire right half is a white box. When I turn the TV off, the left side goes black almost instantly but the right half (the white screen half) goes black after 4-5 seconds after power is turned off. Help, don't have a clue as to what I should do.
  • Anonymous Mar 23, 2014
    White flashing lines where the volume/menu screens appear and do not go away.
  • Anonymous Mar 28, 2014
    DARK RAIN LIKE VERTICAL LINES
    vertical lines flash across the screen at times
  • Anonymous Apr 01, 2014
    i have a line across the screen which you see when the background is white.
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Posted on Apr 21, 2008
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
TV has a great picture but wont "hold it". Keeps going to a single flat horizontal line across the middle of the screen. Tapping on side of TV used to bring it back but now, nothing. Just a line.
Vertical scan output section circuit fault. Absence of vertical scan causes the single horizontal line on screen. Horizontal scan output section is OK. Contact any service technician to troubleshoot the vertical scan output section circuit. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Horizontal line fault to CRT based TVs are given.
Oct 06, 2014 | Televison & Video
Red in picture
Have you tried with a new scart or htm lead?
Sep 23, 2008 | LG 50PX4DR 50 in. Plasma TV
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Dark horizontal line traveling across the screen vertically
on tube tvs bestto go on main bord look for hairline craks on soldering ok redo them nice it will light up happend to mine also older model thx nick
Feb 06, 2008 | Sony FD Trinitron KD-34XBR960 34" TV
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Thin horizontal line across the entire TV screen
Hi, your correct it is collapsed vertically, you should have re-soldered it before it failed because now you may have to replace the IC but I would re-solder it first as this possibly will fix it, look for a small aluminum (silver colored) heatsink with a black 7-10 pin IC screwed onto the heatsink, flip the main board over and this IC will probably have 2-3 (or more) pins broken, re-solder with 60-40 tin/lead solder, you didn`t give make & model number so thats all the info I can give you, good luck, BMW Rider
Jan 14, 2008 | Televison & Video
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
Samsung HP-R4252 42 in. Plasma HDTV Logo
2,927 people viewed this question
Henry  Thomas
Henry Thomas
