Question about Car Audio & Video
My 6x9s have stopped producing bass together
My 6x9s have stopped producing bass. If i unplug one, they work fine individually, but together, they are no longer providing any bass.
  • 407 Answers
There is a short in your wiring somewhere, unfortunately, it would be impossible for me to tell you where it's at. The best advice I could give you is to start at the speakers and work your way back. Hope this helps and good luck!
Posted on Jul 11, 2010
Testimonial: "Brilliant feedback. Speakers now working fine. Thanks!"
It sounds like one of them is out of phase (wired backwards). Check the polarity, or just reverse the polarity on one, even if they both look right. What happens is that, if one is out of phase, on bass notes, one cone moves inward while the other moves out, causing them to cancel each other out at low frequencies. It's only on low frequencies because of the long wavelengths.
Posted on Mar 27, 2012
  • Michael Stigall Mar 27, 2012
    sorry, just realized how old this is and that the problem is already solved...doh!
Cda 9885, When in tuner mode sub does not play
Does you car volume get lower when you stop. If not sounds like an internal issue. No sound at all my brother hooked his up and when he switched to tuner everything would go through the subs but you would not know it sounded like his 6x9s no bass. was a wiring issue. I dont know if this helped or not.
Feb 28, 2014 | Alpine CDA-9885 CD Player
Gigaset a420 has stopped making or receiving calls
You mean unplugged it from the power outlet or the RG45 wall jack? OK so if the battery is fine and you unplugged the power from the source, then the issue is with either the cord itself or the charging unit. Just because the little red light comes on does not mean it is working properly. Put a multi-meter on the charging tabs to double check for continuity. Sometimes and as weird as this sounds, it just takes unplugging a nearly spent power pack/inverter to finish the job so to speak. If you unplugged it from the RG45 then you need to look at the pins in the RG45 wall jack to see if you inadvertently bent one out of shape.Phone won't work if there's no signal. Wish I could help more. Good luck with that issue.
Dec 20, 2013 | Panasonic KX-TGA101S Cordless Handset
I have a koiiler xm-8787 1000w amp. the problem is when i hook everything up correctly, the dual 10 inch sub make a repeating papapapapapapa none stop and doesn't produce bass. could it be the amp is...
I HAVE THE SAME AMP IN MY CAR RIGHT NOW ! THATS NOT NORMAL THATS FORSURE THERE SHOULD BE A X-OVER SWITCH ON THE SIDE OF IT SWITCH IT T0 LPF (LOW PASS) THERE SHOULD BE A DIEAL LABELED THE SAME THING ADJUST IT TI 75% TURN YOUR BASS BOOST TO 25% AND THE LEVEL SWITCH TO 25% THE HPF DIAL WONT WORK UNLESS YOU SWITCH YOUR X-OVER TO HPF BUT YOU DONT WANT THAT, THAT HAS TO DO WITH THE VOICE3 COILS IN THE SPEAKER THATS PROBABLY YOUR PROBLEM! YOU WANT TO RUN YOUR SPEAKERS WIRES PARRALLEL WITH A DOUL VOICE COIL SPEAKER IT SHOULD HAVE FOUR TERMANALS ON IT RUN YOUR NEGATIVES TOGETHER THEN RUN YOUR POSSITIVES TOGETHER AND SEE IF THAT WORKS! GOOD LUCK!!!!!
Oct 22, 2010 | Koiiler XM-6666W Car Audio Amplifier
I own a 1992 Silver City MSN jukebox. I have checked the crossovers and polarity of the woofers. Found 1 speaker to be out of phase. Crossover fine. Better bass, but still weak..How can I increase the bass...
instead of hacking your unit, frankly speaking buy a new one if you want to increase the bass, its circuit is design only to produce that amount of bass sound. the sound it produces depends on how much power its audio amplifier has and how much its powers supply have.
May 05, 2010 | Wurlitzer Jukebox CD Player
No display and Thump and static from bass
The poor display is a known problem.. see my other posts for the cure. As for the thump..a slight one isn't uncommon... but static?- you mean crackling? from the cubes? all of them? unplug the audio leads from the head unit to the bass and see if it stops..then you can narrow it down a bit.
Oct 10, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Bassles Powerplant 6x9s
try reversing the polarity on one speaker.
they might be out of phase.
what happens is the speakers cancel out.
put the balance to one side,and if it has bass,then that is the problem.
if there is no bass with only one playing,then phasing is not the problem
Sep 01, 2009 | Fusion PP-FR692 Car Speaker
Amplifiers GT Series GT5-A604 ........explain settings
the amp probably has a x-over knob, a bass boost knob, and an eq knob. the eq is probably an internal crossover switch that will take the output from either high range (tweeters) or full range (6x9s) or low pass (subs) leave it on low pass. the bass boost however, will add distortion if turned up too high. its not noticable in the car, actually it sounds louder in the car but if you open the trunk and listen, you can tell its distorted bass and actually frying your speakers. the x-over knob is used to tune the frequency at which the amp stops pushing out bass tones. if you like rock music loud, turn it up higher, if you like low deep rap bass, turn it lower. keeping it too high might give you bad sound from either type though. ALSO THE GAIN OR LEVEL.IT IS NOT TO MAKE YOUR SUBS LOUDER IT WILL BLOW THEM .the gain is used to set your amp to your head unit which there is a procedure to do it.
Jun 15, 2009 | JBL GT5A604E 4-way Car Amplifier
My twin jbl 12'' sub in a enclosure dont seem to be giving bass
Those 12's Need to be in a Ported Inclosure to release the Air that the Bass Produces. Use a 1 Inch Key Hole Bit and make 1 Hole at the Top Corner of Each Portion of the Box. Top Left and Top Right. Please Rate My Response! Thanks!
Feb 02, 2009 | JBL GT412 Car Subwoofer
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
No power
You probably have ONE of the speakers wired out of phase.
If the speakers are wired correctly, you may have the crossover set to high pass instead of low pass.
Let me know if you have any other questions.
Aug 11, 2008 | Lanzar VIBE286 Car Audio Amplifier
Car Audio & Video Logo
159 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
